1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
2G Catch can baffling
Posted by PlanZero, Aug 11, 2018
Please Support Morrison Fabrications
  1. PlanZero
    PlanZero Proven Member
    1,367
    257
    Joined Aug 13, 2013
    Easton, Pennsylvania
    If you read my other post you know I've been perusing ebay tonight LOL. Apparently the manufacturers of cheapo catch cans have upped their game a bit; now you can get a "baffled" mini catch can for $25. This one caught my eye because it has two inlets and one outlet and I wanted to run my pcv to the can as well.
    My question to all the catch can experts is does this "baffling" look legit? Supposedly has a 50 micron bronze filter. I don't know enough about catch cans to tell. I'm currently using a single chamber ebay cheapo but it does the job. Any input would be appreciated.
    Here's the link:
    https://m.ebay.com/itm/Universal-Co...an-Tank-Air-Oil-Separator-Black-/263833673612
    Log in/Register to remove ads
    1996 Mitsubishi Eclipse Spyder GST (sold)
    Street Build
    T25   automatic
    1996 Eagle Talon TSi
    Street Build
    16g   automatic
    1997 Eagle Talon TSi AWD
    Street Build
    T25   automatic
    Loading...
    Featured Products from our Supporting Vendors
  2. tametalon92
    tametalon92 Proven Member
    1,558
    321
    Joined Jan 5, 2012
    Rathdrum, Idaho
    So, you want to run your VC vent and your PCV valve to this can, then the outlet to...what?
    Personally I'd like to see the inlet to the can below the aluminum baffle, and I see that filter getting clogged pretty quick. Depends on how baller you're trying to be with your can.
    Ideally you'll want two separate, sealed cans for the pcv and vc individually.
    1997 Mitsubishi Eclipse Spyder GST
    Street Build
    16g   manual
    1992 Eagle Talon TSi AWD
    Street Build
      manual
    Street Build
    14b   manual
    Loading...
  3. DavidJamesDSM
    DavidJamesDSM Probationary Member
    18
    Joined Apr 4, 2016
    Kennewick, Washington
    Curious. Why 2 different catch cans?
  4. tametalon92
    1,558
    321
    Joined Jan 5, 2012
    Rathdrum, Idaho
    Better flow path and no issues with vacuum/no flow with dual sealed cans. Cant really effectively use a single shared can for both vent ports.
    Street Build
    16g   manual
    Street Build
      manual
    Street Build
    14b   manual
    Loading...
    DavidJamesDSM likes this.
  5. DavidJamesDSM
    18
    Joined Apr 4, 2016
    Makes sense. Thanks for the knowledge. After I
    fix my headgasket. A couple catch cans will be next up
  6. 1cleangsx
    1cleangsx Proven Member
    47
    20
    Joined Sep 28, 2013
    Cheyenne, Wyoming
    Actually your pcv valve isnt venting anything under boost, it’s a check valve that only draws in fumes under vacuum, once you remove it then it’s a vent LOL, I don’t think two catch cans are needed unless your running a lot of boost from a massive turbo or you have some gnarly blow by
    1990 Mitsubishi Eclipse GSX
    Street Build
    13.2 @ 104.64 MPH
    Loading...
  7. tametalon92
    1,558
    321
    Joined Jan 5, 2012
    Rathdrum, Idaho
    While correct they aren't supposed to leak, all pcv valves I've tried leak a small amount. Problem is with running both the pcv and vc vent to the same can, is the pcv the becomes completely useless. Most of this will depend on where you run the can vent to: intake manifold? Massive vacuum leak. Pre-turbo inlet? Now you've made the pcv useless.
    Also, under normal operation while in vacuum, flow technically goes from the inlet, through the vc, through the pcv then into the intake manifold. While in boost, pcv valve closes and preturbo inlet becomes the low pressure side and flow reverse, now being drawn from the vc to the intake to relieve pressure. So a single can that's not separated is pointless imo.
    If the objective is to catch oil and keep it out of the intake, while providing as much ventilation and pressure relief as possible, then two cans makes the most sense, or a divided single if you want that complexity.
    Absolute best case is a dry sump or vacuum pump with it's own catch can.
    Street Build
    16g   manual
    Street Build
      manual
    Street Build
    14b   manual
    Loading...
    rEclipserGST likes this.
  8. RamenPride
    RamenPride Proven Member
    2,290
    55
    Joined Aug 18, 2002
    Virginia Beach, Virginia
    Not sure what the filter material is, but looks similar to what you might see in a compressor line filter. I've used one before (in-line filter) and it worked ok. The filter never got clogged because it was made out of something like a porous stone or metal mesh (can't remember), and not paper.
    Loading...
    PlanZero likes this.
  9. lasthope05
    lasthope05 Proven Member
    849
    176
    Joined Mar 31, 2006
    Philadelphia, Pennsylvania
    Sintered bronze.
  10. PlanZero
    1,367
    257
    Joined Aug 13, 2013
    While I understand what tame talon is saying I still want to try the setup (to pre turbo). Jafro gave me the idea and many people run it this way with no problems. The different outlet of the pcv to the CAI instead of the IM supposedly isn't noticeable.
    Again, I'm asking about the baffle not the idea.
    Street Build
    T25   automatic
    Street Build
    16g   automatic
    Street Build
    T25   automatic
    Loading...
  11. rEclipserGST
    rEclipserGST Proven Member
    1,443
    26
    Joined Nov 17, 2007
    Columbus, Ohio
    1995 Eagle Talon TSi AWD
    Street Build
    187 whp   200 lb/ft
    1995 Mitsubishi Eclipse GST (sold)
    13.583 @ 108.440 MPH
    Loading...
    tametalon92 and PlanZero like this.
  12. PlanZero
    1,367
    257
    Joined Aug 13, 2013
    Are you agreeing with me? Scroll down to setup #3. MAXIMUM pressure release. This has been debated for years and I'm not getting into it.
    Again, opinions on the can. It appears to be a knockoff of the mishimoto compact can.
    Street Build
    T25   automatic
    Street Build
    16g   automatic
    Street Build
    T25   automatic
    Loading...
  13. brian9397gsx
    brian9397gsx Proven Member
    1,087
    81
    Joined Apr 28, 2008
    sioux city, Iowa
    I actually have that exact can on my healing bench in the shop. Its honesty a damn nice can the baffling and filtration isn't top notch it wont be 100% but what can will be for 25$. I plan on running it on my daily EcoBoost focus st to swap out the larger one I made. I want to see if the baffling in this one compares to the baffling I made inside my can if so than 25$ is money well spent if you've ever fudged with catch can crap.
    brian9397gsx 1993 Mitsubishi Eclipse GSX
    19.80 @ 35.55 MPH
    Loading...
  14. tametalon92
    1,558
    321
    Joined Jan 5, 2012
    Rathdrum, Idaho
    Like I said, the can would be better if the inlet port went below the perforated baffle, as that's meant to catch oil/water and drop it out of suspension in the air. With the port above it, most of the oil entering the can will end up going right through the brass filter depending on how much vacuum is applied. It will work marginally, but it's definitely not optimized, tho with some cheap modifications it could be pretty good. Just add a tube to the inlet port that drops it below the perforated baffle.
    Street Build
    16g   manual
    Street Build
      manual
    Street Build
    14b   manual
    Loading...
  15. 007jimmy
    007jimmy Proven Member
    1,441
    65
    Joined Feb 27, 2012
    Levittown, Pennsylvania
    I bought that can. Plan on using it once I get my new valve cover on. I'm using 10an adapters to match the valve cover. I think it'll work just fine for a moderate build.
    1997 Mitsubishi Eclipse GSX
    Street Build
      automatic
    Loading...
  16. motomattx
    motomattx Proven Member
    1,156
    245
    Joined Dec 9, 2010
    wampum, Pennsylvania
    Drag Race Build
    GT42   manual
    Loading...
  17. PlanZero
    1,367
    257
    Joined Aug 13, 2013
    ^^ I actually have that one on my watch list as well. I wanted to try the 2 inlet/1 outlet style, and this is a direct copy of the mishimoto can ($116) which is available in 2 or 3 port option
    I realize I'm essentially eliminating my pcv by doing this but that's fine by me. I'll still keep it hooked up (with a check valve) so I have something for the hose to grab onto.
    007jimmy that looks badass with the AN adaptors! Tell me, were the barbs included with the can plastic? I read a review of the mishimoto can and someone said they were plastic.
    Street Build
    T25   automatic
    Street Build
    16g   automatic
    Street Build
    T25   automatic
    Loading...
  18. brian9397gsx
    1,087
    81
    Joined Apr 28, 2008
    sioux city, Iowa
    What made me think about that mini one was how identical it looked to the mishimoto one but at a quarter the price. Not that mishimoto isn't anything other than Ebay parts with great marketing.
    19.80 @ 35.55 MPH
    Loading...
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
