Cas help
Posted by sharky559, May 29, 2010
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support Boostin Performance
  1. sharky559
    sharky559 Proven Member
    Mar 6, 2010
    194
    Sanger, California
    Im confused my 95 eclipse gst has a Cam sensor in the back of the intake Cam. my buddy told me that only jdm motors have the CAS in back of the intake cam. and that DSM motors have them on the left hand side of the motor. someone help i need to know what kind of motor i have.:idontknow:
    #1
  2. kp116
    kp116 Proven Member
    Mar 25, 2009
    491
    Janesville, Wisconsin
    As far as I know all 2ga cars have it in the back of the intake cam. I could be wrong though..
    #2
  3. sharky559
    Mar 6, 2010
    194
    Sanger, California
    Ok so I looked to see where the sensors are and i have a crank sensor at the bottom. and found a cas on the driver side under the intake cam pully. should the cas be on the passangers side like the 1gs. my car is a 95 2g with a 7 bolt engine
    #3
  4. snowborder714
    snowborder714 Moderator
    DSM Profiles:
    Oct 15, 2006
    11,897
    178
    Downingtown, Pennsylvania
    Both the '95 and '96 engines have the CAS behind the intake cam gear. This is normal.
    #4
  5. sharky559
    Mar 6, 2010
    194
    Sanger, California
    Behind like 1g or like behind the cam pully(camshaft interrupter magnet)
    #5
  6. snowborder714
    DSM Profiles:
    Oct 15, 2006
    11,897
    178
    Behind the gear itself (where the timing belt rides).
    #6
  7. sharky559
    Mar 6, 2010
    194
    Sanger, California
    ohhhh ok so. if i put a 1g cas would it make a differ
    one more question im still a noob bro. do 95 eclipse gst have a 7 bolt or 6 bolt
    #7
  8. snowborder714
    DSM Profiles:
    Oct 15, 2006
    11,897
    178
    It would allow you to adjust timing. But it would also cause a random misfire code, which can be quite annoying if not dealt with properly (certain programs can fix this as well as adding in a potentiometer). You can do some searching to find out more about this.
    #8
  9. twalters09
    twalters09 Proven Member
    DSM Profiles:
    Oct 27, 2009
    92
    Harrisburg, Pennsylvania
    95 gst has a 7 bolt to answer that question of yours
    #9
  10. sharky559
    Mar 6, 2010
    194
    Sanger, California
    programs like dsmlink?
    #10
  11. snowborder714
    DSM Profiles:
    Oct 15, 2006
    11,897
    178
    Yep, that program would allow you to not see that misfire code.
    #11
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
