dammitblnk182
- 0
- Oct 31, 2005
Plano,
Texas
Ok. Recently I have replaced my clutch because of having burned both the clutch and the flywheel up when racing. So after the new clutch was installed. My car can't shift into any gears while the engine is turned on. Although, it can shift when the engine is off, so I don't think the syncros have any problems. My performance shop says that it might be the syncros or resurfacing the flywheel though. My flywheel and clutch are new though and are the stock widths so they don't need to be resurfaced. Also, I called ACT and the said that 95% of the problems with engagement of the clutch is because the torque for the pressure plate to flywheel must be 25 lb/ft! My pedal pressure is fine now! I have replaced everything new; the master cylinder, slacve cylinder, clutch line, bleed the clutch a lot, and adjusted the pedal. My mechanic says there's nothing wrong with the pedal or fork. It's a new clutch so there should be nothing wrong with it and also it doesn't need to be resurfaced. I don't know what else i can do to make my car shift into gears, there is pedal pressure so I don't know what's wrong. I really don't want to pay for a transmission rebuild. Please help!
