2gProjectCar
- 65
- 0
- May 19, 2009
Yukon,
Oklahoma
I'm usually pretty good when it comes to fixing my car, but for some reason I can't figure this one out. When I'm driving between 0 - 35 mph the car acts fine. But when i accelerate past 35+ mph the front begins to wobble. Faster speed = more wobble. yes, I've used the search tool already and read over many of the similar threads, but I still can't narrow down whats causing the problem.
So far I have replaced the inner and outer tie rod on the drivers side, and replaced the passenger side cv axle. I've also tried pulling and turning each tire to rule out the hub, there was no movement so the hub is fine. I had a friend lean his head out the window at times while i drove around and he didn't see the wheel itself wobbling in and out. Oh, and i had my tires balanced about a month ago.
Any suggestions or ideas would be helpful.
Thanks
Thanks
