AlexGsxCummins
- 395
- 34
- May 31, 2014
Bremerton,
Washington
I'm running out of ideas here, i replaces plugs, wires, and took it to English racing to have a tune, of course the whole time they had it the problem never came up. So sometimes my car cuts out, i think I've narrowed it down to when the throttle is at WOT or close to it. I can give the car half and let it build just as much boost and it won't do it. Also when this happens the car will idle a little higher (about 1600 rpm) all I can think of is when i set my tps it would not read 5v at WOT but i did set it correct. And another question is if i plug my laptop into the car now that english racing tuned or will i screw up my tune? Also when the problem starts it will continue to do it, i let it sit over night and it runs fine again. Only other thing I can think of that the car will do is once every 3-4 when i go to shift into any gear and do a pull it feels like the car will be pulling back or braking almost then it will all of a sudden just start pulling like normal, it does it for maybe 1 second
