jdm9221
- 125
- 5
- Apr 10, 2017
Osceola,
Indiana
I have a 97 eclipse GSX 16g,550cc injectors,walbro 255,hallman mbc, and a few other bolt ons. So I have the boost controller between the j pipe and and wastegate(yes it's hooked up right,and I've tried both ways). Before I was only hitting 13psi because it was leaking from my bov, replaced that(recirculated to the intake) and now it's hitting 26psi with the boost controller turned all the way down. Also on a side note I've been trying to set a base tune using my safc2 and my wideband. Hi throttle points are set -37 all the way across and it's still running 9.6 under boost, does this seem right to keep going lower considering they're only 550s and the safc maxes to -50? Any help is appreciated
