cam identify?
Posted by Drifter27_04, Dec 7, 2005
Please Support STM Tuned
  1. Drifter27_04
    Drifter27_04 Proven Member
    310
    Joined Feb 13, 2005
    Winston Salem, North Carolina
    Hey you guys, I am needing some help identifying a set of cams I have. I bought a car and the guy I bought it from did not tell me it have cams in it but as I am rebuilding they are not to look stock cams. The only thing I can say is that of the following etching below:
    It has "CWC" on both cams
    On the intake it has "C-1" and "D-5"
    On the exhaust it has "C-2" and "E-29"
    Can someone help me in indentifying the following so I know what I am looking at and find the specs of the following cams?
    Thanks
    Log in/Register to remove ads
    My DSM:
    1990 Eagle Talon TSi AWD
    12.140 @ 109.000 MPH
    Loading...
  2. Defiant
    Defiant DSM Wiseman
    25,202
    123
    Joined Jan 13, 2003
    glorious Galt, California
  3. dvbrien
    dvbrien Proven Member
    79
    24
    Joined Nov 3, 2005
    Rockton, Illinois
    I was told that my car has Crower Cams but when I pulled the valve cover off I couldn't find their stamp anywhere. All I found was... On 1 end I found D2 on each cam on the other end I found EP4604... Could Anyone please tell me what this is / From? Please... I think these are stock cams but, not certain. If they are could you please show me where I can find evidence that they are... I am taking the seller to small claims for the Many Lies he's told and misrepresentation of the car...
    Thx DvB
  4. bloody_angel111
    bloody_angel111 Proven Member
    188
    Joined May 28, 2005
    turtle creek, Pennsylvania
    i have crower stage 2's, and mine dont say anything on them about being crower, all thats one them is a T and a EP or something ontop between the lobes, if that helps, i have no idea
  5. Defiant
    Defiant DSM Wiseman
    25,202
    123
    Joined Jan 13, 2003
    See link above.
    My DSM:
    Loading...
  6. TommyDSM
    TommyDSM Proven Member
    224
    Joined Aug 2, 2003
    Somewhere, New York
    Sorry to bring and old thread back, but my cams also say D2 EP4604 But also says
    C2 E8 CWC, Webcam 547 3/00
    D1 Ep4606
    C1 E8 CWC, Webcam 546 3/00.
    When I purchased my car was told it had race webcams. So I guess I do. I hope that helps.
  7. talon96tsi
    talon96tsi Proven Member
    151
    Joined Feb 16, 2003
    Westminster, Maryland
    Does the 547 refer to the lift? if so those are massive. Please reply with and answer I just bought Webcams that are marked c2 with EP4604 and am trying to figure out just how big these really are.
  8. TommyDSM
    224
    Joined Aug 2, 2003
    Somewhere, New York
    546/547 Refers to Grind Numbers... Vavle lifts for those Grind Numbers are .400/.385, Duration in Degree is 272. Hope that helps.:cool:
  9. Drifter27_04
    310
    Joined Feb 13, 2005
    Is there anywhere I can go to check out the different webcams and description of them.
    I have the number written down on a piece of paper at home but I am not there. I do know that my cams read different from yours. Mine does not read E8 (if I am correct it showed E29), did not see D1 (I do recall seeing a D5), EP4606, C1 (intake; off top of my mind), C2 (exhaust; off top of my mind).
    My DSM:
    Loading...
  10. TommyDSM
    224
    Joined Aug 2, 2003
    Somewhere, New York
    You probably have a different Grind number also... maybe the 274 or higher...
  11. Drifter27_04
    310
    Joined Feb 13, 2005
    Do you know where I may find these numbers and view them?
    My DSM:
    Loading...
  12. TommyDSM
    224
    Joined Aug 2, 2003
    Somewhere, New York
    Well I got the info awhile ago not sure where it resides now.
    But you look at the Grind Number
    546/547, Valve Lift of .400/.385 and Duration in Degrees 272
    Designed to bolt into a stock engine to increase overall performance. Stock fuel injection OK.
    452/228, Valve Lift of .415/.390 and Duration in Degrees 274
    Increases mid and upper end power for built engines. Racing springs recommended. Turbo use OK. Programmable fuel injection required!
    453/228, Valve Lift of .415/.390 and Duration in Degrees 276
    Increases mid and upper end power. Racing springs recommended. Turbo use OK. Race profile only! Programmable fuel injection required! A WEB CAM winner!
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
