Cam Angle Sensor Test
Posted by mharrison, Sep 30, 2007
Please Support ExtremePSI
  1. mharrison
    mharrison Proven Member
    45
    Joined Feb 7, 2006
    Madison, Mississippi
    The above is from another thread. When I unplug my Cam Angle Sensor, the car just dies immediately. Does this mean it's bad? Or is the above test not valid?
    Log in/Register to remove ads
  2. absolute_DSM
    absolute_DSM Proven Member
    1,552
    8
    Joined Jan 29, 2006
    Boise, Idaho
    I dont know what that guy is talking about.
    Your CAS controls your spark. No CAS, no spark.
    Are you thinking your CAS is bad? If so, do a simple CAS test.
    Unbolt the CAS from the head.
    Pull all your spark plugs.
    Turn the key to the ON position (engine NOT running).
    Spin the CAS to verify all your spark plugs spark.
    Locke likes this.
  3. mharrison
    45
    Joined Feb 7, 2006
    Well, I have an intermittent miss. It tends to miss under idle (most of the time) and occasionally under acceleration. Also throws a P0302 code.
    Coil Good, Plugs Good, Wires Good, Injectors Good, trying to find the problem.
  4. absolute_DSM
    1,552
    8
    Joined Jan 29, 2006
    Boise, Idaho
    How do you know they are all good?
    Did you test the coils? Plugs are NGKs? Grounds are good? Injectors are cleaned?
  5. mharrison
    45
    Joined Feb 7, 2006
    I appreciate the input. Here are the responses:
    Replaced the coil with a brand new one. No Change. (I had access to one at no charge!)
    Plugs are NGK's. All plugs work in all cylinders except #2. Verified this by swapping them around. They all still generate a misfire in cylinder #2 according to the computer codes.
    What grounds?
    #2 Injector has been replaced, others indicate no signs of being problematic. Can hear the electromagnet in all coils firing.
    Compression is good on all 4 cylinders.
    Timing is good.
    Car was running like a top with a new timing belt, new water pump, and rebuilt head for about 5k miles before this misfire occurred.
    Throttle body has been cleaned.
    EGR valve has been tested.
  6. Locke
    Locke N/T DSM Wiseman
    2,683
    12
    Joined Jan 1, 2005
    Houston, Texas
    Don't put all of your faith in the ECU's determination of specific cylinder misfire.
    Try checking the connections at the knock and crank sensors, and that the magnet in the cam sensor is not cracked.
    My DSM:
    Loading...
  7. laserspeeddemon
    laserspeeddemon Proven Member
    1,789
    33
    Joined Jul 26, 2002
    Fredericksburg, Virginia
    What year and model car are we referring to?
    Loading...
  8. mharrison
    45
    Joined Feb 7, 2006
    97 Mitsubishi Eclipse GS.
    420A Engine.
    5 speed Manual Transmission.
    No Mods.
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
