Ystwaspen
- 0
- Sep 4, 2014
Oakhurst,
California
Call or text for fastest reply! Chad 559-676-7768
IF YOU DONT SEE A PICTURE OF SOMETHING LISTED, PLEASE ASK!!
HOT BITS DT2 COILOVERS!!!
Setup has around 5000 miles on it. Everything is in great condition as you can see. This is a great setup for these cars and you cant go wrong.
Height adjustable
40 step rebound damping adjustment (80% change)
30 step compression damping adjustment (50% change)
$1300 for a great setup!
Slightly used Baer BBK
Everything worked great when pulled. No leaks, No cracking, and pads have plenty of life left. The kit has around 2000 miles on it however the car sat for a while. I put the rotors in the blast cabinet to clean off the surface rust.
$500
1G ETS 7 inch Street Intercooler and piping kit!
1 pipe has been modified to tuck tighter on the drivers side.
$350
Denso 800cc Turbo RX7 Injectors - Low Impedance - DSM compatible (requires tuning. PN: 195500-0610
All 4 are matching. One needs a $.50 pintle cap and rubber seals. All need upper o-rings.
$100
BRAND NEW!!
1990-1994 Eclipse And Galant VR4
JNZ Short Shift Kit for 1G DSM and others. With Symborski Bushing kit.
$100
TORQUE SOLUTION FRONT ENGINE MOTOR MOUNT 1G DSM ECLIPSE 1994 94
$60
Fuelinjectorclinic.com 1100cc High-Z Injectors only 2,000 miles on them
$300
Montero 3inch MAF with Harness adapter and 3-4inch adapter plate with brand new k&n e5t08071
$125
Hallman manual boost controller. Pro series Evolution Comes with light and heavy springs. Great condition!
$80
FRH Intake manifold!
JAM Spec Forrester Intake Manifold Kit w/75mm Billet Throttle Body
Brand new, been sitting on a shelf since it was purchased in 2010. Has never been mounted to anything.
Your chance to buy this discontinued part BRAND NEW!
$500
SAFC $100 (sold)
Fan with wiring and relay $35
Sun pro boost guage $25
VDO boost guage $25
Mature/Low Key exhaust with gutted catalytic converter for a 1g DSM. Sounded great and wasn't too loud. Uses all the factory mounting points and splits into different pieces like you see in the picture.
I may consider splitting the down pipe and cat from the rest.
Make reasonable offer. I can ship at buyers expense however it will probably cost a pretty penny.
Miglia 1000's wheels and tires
17x8 5x114.3 et35
225/45r17 Two tires are worn down but hold air. The other two have some life left.
Rims show wear and have curb rash
$3000
1990 Elcipse GSX
127,XXX Miles and a Clean title
2 Owner car
CURRENT REGISTRATION!
All original vin tags
3.54 viscous rear LSD
California car NO RUST Located in FRESNO CA
Comes with a very clean and nice interior. Lsd rear diff. Front and rear strut braces. A well setup battery relocation kit. A Nice low key exhaust and stainless down pipe. Great looking front bumper.
CAR DOES NOT HAVE THE FOLLOWING ITEMS PLEASE BRING WHAT IS NEEDED TO LOAD IT ON A TRAILER. Front brakes, struts, engine, wheels, tires, transmission, transfer case radio, and a few other items I am missing.
Pictures are crappy because my shop isn't very well lit. Going to post better ones up soon. Last picture is right before it was torn down.
$1100 as is
$1350 with 5 speed manual and transfer case
I can deliver for additional costs
FULLY BUILT LOW COMPRESSION MOTOR
Compression test: as follows
Cylinder 1 165.0 psi
Cylinder 2 164.5 psi
Cylinder 3 165.0 psi
Cylinder 4 164.0 psi
JAM SPEC 2.4L 4G64 Fully Built 750whp Capable Motor
-Deck Bolt / Main Bolt Holes Bottom Tapped
-Line Bore
-ARP Main Studs
-Cylinder are 4-Step Torque Plate Honed
-Bottom End Balance
*New 100mm Forged Steel Crankshaft
*Wiseco Forged Pistons 86.5mm 8.5:1 CR
*Piston Squirters
*Eagle Connecting Rods w/ARP 2000 Bolts
*Performance Coated ACL Engine Bearings
*Performance Coated ACL Balance Shaft Bearings
*ARP Main Stud Kit
And there's MORE
*Cloyes Cam Timing Belt for DSM $59.95
*P.E. Strong Balance Shaft Belt $59.95
*JAM Spec ARP Head Stud Kit $79.95
*JAM Spec Kelford Camshaft 2.0 4G63 272/272 Set $585.00
*JAM Spec Complete Engine Gasket Kit + Copper Perforated Head Gasket $185.40
*JAM Spec Stage II CNC Race Ported Cylinder Head 2.0 4G63 6-Bolt $2,285.00
*JAM Spec Forrester Intake Manifold Kit w/75mm Billet Throttle Body $1,250.00 (BRAND NEW NEVER INSTALLED)
ALL THE ABOVE WAS DONE ABOUT 5000 MILES AGO!!! Have receipts for all the above! Engine was properly broken in and adult driven. Ready for TONS of power!!
Built Long Block - $3200
Head with Cams - $1800
Bottom End - $1800
South Bend Clutch SUPER HeavyDuty TZ/B-Series Kevlar/Ceramic Clutch Assembly for the 1G and 2G FWD/AWD DSM ($585 new) with ACT Streetlite flywheel ($260 new) Less than 5000 miles on it. $300
Height adjustable
$500
$350
$100
BRAND NEW!!
$100
$60
$300
$125
$80
$500
SAFC $100 (sold)
VDO boost guage $25
17x8 5x114.3 et35
$3000
1990 Elcipse GSX
2 Owner car
$1100 as is
-Line Bore
-ARP Main Studs
-Bottom End Balance
*Piston Squirters
*ARP Main Stud Kit
And there's MORE
Bottom End - $1800
