twicks69
Supporting Vendor
- 4,203
- 1,663
- Mar 12, 2004
Milwaukee,
Wisconsin
Hey everyone, it has been a while since I have fooled around with building an engine so I am open to hearing feedback from members regarding the assembly.
The setup is:
97-99 Split Thrust 4G63 Block
Manley 94mm billet 7-bolt crank
R&R 153mm aluminum rods 23mm pin, 3/8" L19 fasteners
Diamond 3.3661" bore 2618 alloy custom pistons
Diamond Pro Select Piston Rings
ACL HX-Series main and rod (drilled) bearings
ARP L19 1/2" Head Studs
ARP Main Studs
I have several questions to confirm / answer regarding block clearancing, machining and assembly:
Block clearancing:
The block I am working with is currently a stock torn down motor, no machining done yet.
With the block clearancing, I just have a stock piston and stock 22mm wrist pin sitting on an aluminum rod; I didn't want to fool around with drilling a stock piston to take a 23mm pin and have it waste time. So that would be a ~0.039" pin gap on the rod currently.
With block clearancing, should I stick with a minimum of 0.080" of clearance between aluminum rod and block webbing/ cylinder walls? I was assuming a minimum of 0.060" + the 0.020 from the pin gap.
Block machining/ block filling:
I am assuming after I have a clearanced block, I should pull the freeze plugs and port plugs, and it should be baked to remove the oxidation, then hot tanked.
I will have the oil squirters in the mains drilled, tapped and plugged. Anyone know the sizing typically used for tap/plugs?
I have a torque plate here, and I will be using L19 1/2" studs. The cylinder head will have my shouldered 1/2" dowels in it too when it comes to actual assembly. It is looking like I will be doing a full-filled block and running water through the head only. I am assuming I will be welding the water ports on the head then? Are you guys welding on a -16AN ORB weld bung onto the cylinder head then by the cam gear side after removing the freeze plug? The block and head(s) are not o-ringed currently. I am assuming that if I do a full fill, then I will be using a solid copper head gasket and a stainless steel o-ring in the head and a receiver groove in the block? If I do a 1/2 fill, then I will be using a MLS gasket made for the 1/2" studs and no o-ring, and have open ports on the cylinder head with the water going through the regular electric water pump -16AN adapter plate I am running.
For filling up the block with hard-blok, is there a method that works the best? If funnels, got any pics or dimensions? I will set up my pneumatic vibrator to either bolt on or make a magnetic base for it. Do you use clay, or something else to plug up all the water outlet areas?
Piston to wall (PTW):
Recommended PTW for the Diamond pistons is a 0.0035" minimum spec, now being a half or likely a full fill block, should I shoot for 0.0045"-0.0055" with a 1/2 fill block and 0.0055-0.0065" on a full fill block?
Ring gaps:
The motor will be in the 50-65psi range on gas or E85/mix.
I have not used Diamond piston rings before. They use a symmetric silver stainless steel 1st upper ring and an assymetric 2nd lower ring. The rings are numbered N150; I am assuming that this is also the top of the ring marking. Now with the ring gaps, are these like Total Seal gapless rings where I should be doing a bore x 0.008 for the top and a bore x 0.007 for the bottom rings? which would be 0.027-0.028" gap top and a 0.023-0.024" bottom gap. Build sheet shows bore as 3.3661 on piston. And then a minimum oil rail gap of 0.015" for both of the rail rings?
Installation:
With the pistons, I am assuming the identification mark on the top of piston faces the timing belt side for them. With the rods which orientation should I do, the R&R logo / rod bearing locks facing the front or the rear of the engine block? Logo/Locks face front of block correct?
Rod bolt torque out-of-box / stretch / torque spec for assembly:
The rod bolts are torqued out of the box, I'll have to check the initial figure. I am assuming the rod bolts installed out-of-box before removal are at ZERO STRETCH? I will set up the connecting rod in my connecting rod vise and will use a bolt stretch gauge. Recommended stretch is 0.0065"-0.0070" bolt stretch for the 3/8" ARP L19 bolts, and a spec torque value LIMIT of 75 ft/lbs. Is there a value that you guys are torqueing the rod bolts to on average for these fastners to see the desired bolt stretch range? I have a 3/8" box wrench adapter for my torque wrench I will be using IF it fits. Guessing I'll have to use a standard 3/8" 12-point socket on the torque wrench then check bolt stretch every time. R&R specs using 50W motor oil for the assembly / stretch measurements on the rod bolts. Should I cycle the rod bolt 3 times to the final stretch value?
Rod bearing and main bearing sizing:
I am using ACL HX-series bearings for mains and rods. The motor will be on 20w50 oil. The rod bearings are already drilled for the pins in the rod caps. I have a couple sets of main and rod bearings to work with.
With the aluminum rods, I am assuming I should have the rod bearing gap around 0.0025-0.0030"? or should I be a looser in the 0.0030-0.0035" rod bearing gap on the aluminum rod? With the mains, should i shoot for 0.0020-0.0025"?
I think that these are most of my questions, or things swirling around in my head currently to just confirm.
Thank you all for your insight in advance!
The setup is:
ARP Main Studs
Block clearancing:
Ring gaps:
Installation:
