BSE "kit" NOT to use!!
Posted by stuckwithgsx, Nov 8, 2011
Please Support Strictly Performance Motorsports
  1. stuckwithgsx
    stuckwithgsx Proven Member
    228
    Joined Sep 5, 2006
    Phoenix, Arizona
    Ok so I bought the BSE kit from ebay (bad choice to begin with) and installed it into my 95 7 bolt block. Not knowing that there was a difference between the cheap kits and expensive kits. I mean it's just a stub shaft, a plug, and some bearings right? ...Wrong!!
    So this is the kit that I bought.
    And after ~130 miles of driving I noticed a little tick. Now this car had lifter tick pretty bad before the BSE. After putting it all together there was lifter tick no more :) So when I heard this "tick" sound I figured lifter tick was back (same lifters) but getting to ~200 miles after the build it was getting worse. When 300 miles came along it was bad. At 350 miles it became a loud knocking sound, something was going really wrong. So I parked her. Started the car and revved it while in the engine bay and the sound was pretty obvious on the top side of the engine but could not pinpoint it, at idle everything sounded great, but revving above 2500 rpm's something was definately wrong. So I had a friend come over and had him rev it up while i listened underneath the car.... It sounded like something was about to knock the oil pan completely off!! Ok that was a little dramatic, but the sound was horrible under there. I shut it off and began to tear the engine out.
    I will have to post more pictures of the rod bearings. #2 was pretty worn out and got toasty.
    The main bearings were the worst.
    Here's the cap side:
    And here is the block side:
    Now in conclusion the bse kit had everything there that i needed. And not observing there was no oil groove in the stub shaft, i put it all together. I am still THINKING that this is what caused my problem. There is definately oil starvation to all main bearings.
    This is an example of a kit that I SHOULD of bought (MAPerformance):
    Now I still need to update a confirmation that the oil groove in the stub shaft does in fact directly relate to the oil galley feeding the main bearings. As of this moment I don't know for sure, but I will know and update soon.
    This is just a warning to all who plan on going with the cheaper bse kits and the problems I have encountered with it.
    Car history:
    Timing belt snapped, so head was pulled and completely gone through with all new valves, seals, and seats. It was done by my local machine shop, cleaned, and milled as well. While that was all out, off, and apart I wanted to do the bse as well. I removed the rear shaft (closest to firewall) and replaced it with the stub shaft. The block was still in the car, and a big pain to work with so I ended up leaving the front shaft (closest to radiator) inside and just putting some loc-tite around everywhere on the oil pump gear to ensure it wouldn't move. I've read of a few people that have done this with no issues. So I had no need for the bearings or plug that came with the bse kit.
    I did replace the oil pump with an ebay knock off as well. I had compared the old one to the new one side by side and they looked the same, other than the hole/spacer that the lower alternator bolt goes through. The new pump's hole/spacer was about 1/2" shorter than the stock one. So I got to looking and concluded that where the hole/spacer is located there is no oil passages behind there. So I simply cut the hole/spacer off of the new pump, as well as the old pump. So currently part of my block is showing that is not normally showing, and i just have a big cylinder spacer type piece for my lower alternator bolt. As of the day the car was parked and torn apart there was no leaks at all because of this, so i see no problem with what I did (other than the fact I should of just won the lottery and bought oem stuff LOL). And to top all this off the oil pressure gauge (stock) read normal.
    So all in all there could be 2 reasons that these bearings failed. I am 99.999% sure that the bse kit that I put in there is the cause.
    Again i'll come back and update this all tonight with better pictures, and start looking into the way the oil pump, and block distribute the oil. Then I will know 100% where the problem came from.
    I have updated my profile and everything is current. The only things that changed from the broken timing belt are new timing belt, timing auto tensioner, oil pump, bse kit, arp head studs, all the head work, and head gasket.
    I know this is all a little jumbled, and i'll be back tonight to revise it much better. If anyone has any better input, or more information on this please add it, or pm me and i'll add it. And now I noticed I need to resize some pictures and I will.
    I've also looked and looked and have not found any threads or information regarding this product. Let me know if the information is already out there. Thanks!
    Log in/Register to remove ads
    Loading...
  2. Lofty
    Lofty Moderator
    1,436
    27
    Joined Jul 27, 2008
    Waukesha, Wisconsin
    I'm almost sure that the oilpump flows partly through that ridge in the shaft.
    If you look there's a little hole on the top of it and the bottom.
    My front case was just off, I really could have verified, but I'm almost sure that's how it works.
    Without that groove I'm assuming you impede some of the functionality of the oil pump if not all.
    My DSM:
    Loading...
  3. stuckwithgsx
    228
    Joined Sep 5, 2006
    Phoenix, Arizona
    I do believe you're right.
    I went to take the back housing off of the pump and ended up stripping the screw driver type bolt. I must have put a dab of lock-tite on it. So I started drilling it out so that I could use an 'easy out'...well 4 drill bits later and nowhere near deep enough to get the 'easy out' in there. So I went and bought a titanium coated bit today on my lunch and going back at it tonight.
    I talked to my local machine shop as well and he said it may just be an oil pressure relief valve. I don't know if it's in the area with the pump gears, but we're thinking so. He said there should be a plunger, spring, and a ball. Hopefully I can get in there without completely destroying the pump :D
    This has just become a huge nightmare! LOL
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports Tire Rack VR Speed Factory
