Broken Oil Pan Bolt
Posted by OblivioAssebit, May 4, 2010
420A Bolt-on Tech - Intake, exhaust, ignition, fuel system, cooling, etc - specific to 2G N/T DSMs. New Members must limit their 420A tech posts to this forum.
Please Support Boostin Performance
  1. OblivioAssebit
    OblivioAssebit Proven Member
    DSM Profiles:
    May 15, 2009
    139
    Highlands Ranch, Colorado
    So I was working under my car and noticed I had oil seepage around my oil pan gasket. As I looked closer it looked like one of the bolts wasnt tightened all the way because there was a bit of a gap. So I grabbed my 1/4" ratchet with about a 3 inch handle and tried to tighten it. Well, it snapped will all of about 2 fingers worth of pressure. I didnt over tighten them when I replaced my gasket, and I used a torque wrench, nor did I use nearly enough strength to snap that bolt.
    Anyways, does anyone have any suggestions on how to get that broken bolt out? And should I use grade 8 next time or is that too strong? I dont want to crack the block with a bolt thats stronger than the block. I plan on pulling the pan anyways to weld on my return bung. Also is my gasket reusable. I swore I read that somewhere. Its pretty new. I did my rebuild last spring. About a year ago.
    #1
  2. Fotowntalon
    Fotowntalon Proven Member
    May 14, 2008
    1,036
    8
    Fostoria, Ohio
    i forget the proper term, but they make a special tool to get broken bolts off, think they are called a "tap" or something, my brain isnt working at the moment. Another way would be to take your oil pan off and get it that way, although you would have a lot of oil going everywhere, could probably drain most the oil through the oil filter. Best of luck!
    #2
  3. OblivioAssebit
    DSM Profiles:
    May 15, 2009
    139
    An easy out? The drill bit that.."drills" in the opposite direction? I was thinking one of those but I dont have a lift so everything I do is going to have to be on jackstands And I dont know if I can get a drill to fit up and down to get it out. I am taking out my oil pan no matter what tho. I need to tap it for my turbo set up.
    #3
  4. dsmking101
    dsmking101 Proven Member
    May 13, 2009
    223
    ????, Utah
    my advice to you about the gasket is if it was reusable i wouldent re use it get a new one that way youll have a good and proper seal and not leak fluid== i think they are reusable some one correct me if im wrong but ill buy a new one to be on the safe side...
    #4
  5. Fotowntalon
    May 14, 2008
    1,036
    8
    Fostoria, Ohio
    i just did my crank scraper today so i got to see my old oil pan gasket, they look very solid, i dont think it would hurt to reuse it, its not like a valve cover gasket or IM/TB gasket, it looks like they have washers in it around the wholes, and by how sturdy it is, it wouldn't surprise me if there was a fine layer of metal throughout the whole thing. But speaking of which, if you are going to take your oil pan off, might as well install a crank scraper :p
    #5
  6. 96_killer
    96_killer Proven Member
    DSM Profiles:
    Jul 23, 2005
    179
    San Antonio, Texas
    yes are pan gasket have a steel inner core and spacers on the bolt holes to keep from crushing the gasket. i have reused my pan gasket it was solid and had no ware, so i cleaned it with brake cleaner and put a small bead of RTV on both sides and I still have no leaks...
    #6
  7. Locke
    Locke N/T DSM Wiseman
    DSM Profiles:
    Jan 1, 2005
    2,683
    12
    Houston, Texas
    You can easily lift the vehicle high enough to clear a drill with bit. You don't need to use a drill to extract the screw with the easy-out; I would actually recommend against it. Once you drill the bolt, place the screw extractor into it and give it a very gentle tap with a hammer to get it started in there, then turn it out by hand. I use a t-handle tap wrench with screw extractors, but you could use a standard wrench of some sort as well.
    If you cannot get it and are willing to remove the oil-pan, clean the block on both sides near the hole with the broken bolt, then heat the block with a torch. This will make it much easier to get the broken screw out.
    If that doesn't work, purchase a helicoil (or equiv.) kit and use that.
    I would not use a grade 8 bolt (class 10.9) for fear that it would be stronger that the block. Stick with a class 8.8 in this case. It's generally better to break a bolt than to strip the threads out of a bolt hole, IMO.
    #7
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
