181161
- 107
- 37
- Mar 19, 2011
El Paso,
Texas
My friend sold me a STM wilwood brake kit for an evo. I need to make a bracket that fits the 2g dsm. I do have the bracket for the evo which i used as a guide for the bolts on the caliper side. I made a template out of cardboard that bolts to the caliper and left the other side blank. I mounted the rotor and approximated where the caliper would sit with the cardboard attached. I marked the cardboard based on the holes on the knuckle side. I essentially have a rough draft of a template which I can translate to a thick sheet metal, once I get it nearly perfect, to use as an official template. I can upload pictures of what I have so far in the comments later. I guess the point of this post is to see if anyone has any better ideas that can help make this process a bit easier. I figured if I have a useable template my friend can machine it out as opposed to charge me for this entire process.
