1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
2G BOV "situation"
Posted by KoalaFD, Aug 12, 2018
Please Support STM Tuned
  1. KoalaFD
    KoalaFD Probationary Member
    4
    Joined Aug 12, 2018
    Long Beach, California
    So... I'm new, hello.
    We got a '96 Mitsubishi Eclipse GSX a couple of days ago as a trade for some work done. It was previously neglected and wasn't started for about 10 years. But it started up pretty good after the fuel pump was changed. We're gonna hopefully restore it back to some semblence of glory.
    Anyways, just wanted to post this picture. Not really looking for solutions (I think I know what to do) and not claiming to be an expert on DSMs but I think something(s) is/are not right here... If this is an established and proper way to do things, though, please let me know.
    Log in/Register to remove ads
    Featured Products from our Supporting Vendors
  2. 2gmitsueclipse
    2gmitsueclipse DSM Wiseman
    2,018
    577
    Joined Jul 13, 2005
    Auburn Hills, Michigan
    The BOV should not be mount VTA (vent to atmosphere) without some method of tuning. In stock form, the ECU factors in the air that is released back into the intake when the BOV opens. Pictured below is the correct routing of the 2g BOV. I may suggest, if you are looking for an upgrade, go with the metal Evo BOV as it would be a direct replacement for your current setup. You are currently missing a hose that connects the black plastic BOV to the inlet pipe for the turbo. The silver HKS item is not needed.
    1998 Mitsubishi Eclipse GSX
    Autocross Build
    T25   manual
    1999 Mitsubishi Eclipse GST
    Street Build
    16g   manual
    1990 Plymouth Laser RS Turbo
    Autocross Build
    14b   manual
    Loading...
    PlanZero likes this.
  3. m_0ney_pit
    m_0ney_pit Proven Member
    578
    27
    Joined Jan 12, 2007
    Reading, Pennsylvania
    Lol is that a wastegate in the intake recirc hole?
    1998 Eagle Talon TSi AWD
    Street Build
    14b   automatic
    1999
    Street Build
    16g   manual
    Street Build
    14b   manual
    Loading...
  4. KoalaFD
    4
    Joined Aug 12, 2018
    Heheh, great, thank you. That's pretty much what I was planning to do - get it back to recirculate. Also, I'm pretty sure the stock 2g BOV is mounted backwards - like the BOV outlet is plugged in.
    The picture was mostly for chuckles. Because I chuckled and shook my head a little bit when I saw the real life situation.
  5. KoalaFD
    4
    Joined Aug 12, 2018
    No... it's an HKS BOV. That's venting the... intake... pre-turbo side to atmosphere.
  6. PlanZero
    PlanZero Proven Member
    1,367
    257
    Joined Aug 13, 2013
    Easton, Pennsylvania
    HKS my ass LOL. Alibaba.
    1996 Mitsubishi Eclipse Spyder GST (sold)
    Street Build
    T25   automatic
    1996 Eagle Talon TSi
    Street Build
    16g   automatic
    1997 Eagle Talon TSi AWD
    Street Build
    T25   automatic
    Loading...
  7. KoalaFD
    4
    Joined Aug 12, 2018
    A good point. Now that you mention it, it’s very “plasticky” for an true HKS product. As in, it’s mostly made of plastic.
  8. pauleyman
    pauleyman DSM Wiseman
    4,824
    837
    Joined Nov 19, 2011
    oklahoma city, Oklahoma
    That now tops my list as the dumbest thing I've ever seen. Previously the dumbest was a "boost source" tapped into the intake pipe pre turbo by cutting a slit and sticking a vac hose in it. Owner wondered why his boost controller didn't work.
    Street Build
    T25   manual
    Loading...
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
