2G Bov opening under acceleration
Posted by JuGs, Mar 20, 2017
Please Support Race Components Inc
  1. JuGs
    JuGs Proven Member
    590
    Joined Jul 20, 2008
    Marshall, Wisconsin
    Ok so what can cause my bov to open while accelerating? I know it shouldn't open unless let off throttle.
    Its a 1g bov all hard ic pipes. 16g turbo.
    Log in/Register to remove ads
  2. ec17pse
    ec17pse Freelancer
    2,532
    660
    Joined Nov 1, 2008
    London, Europe
    Seems like the spring is weak, have you tested it to see when it starts to open as you may need a new bov
    My DSM:
    1997 Mitsubishi Eclipse GST
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  3. jakk220
    jakk220 Proven Member
    768
    93
    Joined Nov 13, 2010
    Akron, Ohio
    I second that. Sounds like you need a new blow off valve. You could be over running it or its just old.
    My DSM:
    1997 Eagle Talon N/T (sold)
    Autocross Build
      manual
    1993 Mitsubishi Eclipse GSX
    Street Build
    16g   manual
    Loading...
  4. doubleclutch
    doubleclutch Supporting Member
    595
    121
    Joined Jun 26, 2009
    Canton, Michigan
    You could "crush" it. Increase the spring preload to help it stay shut.
    My DSM:
    1998 Mitsubishi Eclipse GSX
    Street Build
    16g   manual
    1996 Mitsubishi Eclipse GST (sold)
    T25   manual
    Loading...
  5. JuGs
    JuGs Proven Member
    590
    Joined Jul 20, 2008
    Marshall, Wisconsin
    I was actually going to try that. Or buy the NGR type greddy rep one.
    It opens after 3500 rpms or after a few lbs of boost.
  6. tametalon92
    tametalon92 Proven Member
    1,240
    212
    Joined Jan 5, 2012
    spokane, Washington
    How is your vacuum line routed to the bov?
    My DSM:
    Loading...
  7. JuGs
    JuGs Proven Member
    590
    Joined Jul 20, 2008
    Marshall, Wisconsin
    Yes. Straight to the intake. I've replacedthe line as well with new. Still does it.
  8. tametalon92
    1,240
    212
    Joined Jan 5, 2012
    spokane, Washington
    I assume you mean intake manifold. If that's the case, then yes it would seem the spring is weak.
    My DSM:
    Loading...
  9. JuGs
    JuGs Proven Member
    590
    Joined Jul 20, 2008
    Marshall, Wisconsin
    Yes the intake manifold.
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrications OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports Tire Rack VR Speed Factory
