Bosch 044 In tank Pre Filter
Posted by Irrational, Jul 16, 2007
Please Support Extreme Turbo Systems
  1. Irrational
    Irrational Proven Member
    226
    Joined Feb 27, 2004
    Belmar, New Jersey
    So i got my Bosh 044 in the tank with 8an feed. when i try putting the thing in with the pre filter i got from Jay Racing. It does not fit the fuel pump assembly is taller then the tank so you cant bolt the assembly down. When I take the filter off it goes in like a champ.
    Are you guy's running Pre filter's with your in tank 044's?
    here is a pic of how tall the set up is. I would shim it up a bit but then i wont be able to get the cover back on.
    Log in/Register to remove ads
  2. 99gst_racer
    99gst_racer Moderator
    8,963
    554
    Joined Apr 5, 2003
    Coloma, Michigan
    The DSMtak write-up lists it as "optional but good insurance".
    You could also try shimming the bulkhead up with another lock nut.
    My DSM:
    Loading...
  3. Irrational
    226
    Joined Feb 27, 2004
    Belmar, New Jersey
    I did not see anything about a pre filter on Nukafision's wright up, and he did 6an i wonder if 8an bulkheads and adapter's are longer.
    I was talking about shiming it but i cant go far before the an is in the car.
    Let me refraze my question- Does anyone here have a different Pre filter that fits with the 8an setup?
  4. vintagemuscle
    vintagemuscle Proven Member
    310
    11
    Joined Jul 19, 2005
    north olmsted, Ohio
    I run a bosch 044 in tank without a filter. I also use all -8an fittings and have not had a problem. If I knew about this pre-filter before I put it in I probably would have used it.
    If you look at the inlet of the bosch pump you can see that it has a built in filter and should work fine unless you have a whole bunch of crap in your tank.
    My DSM:
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
