Boostin Performance
- 396
- 200
- Jan 7, 2014
Hoffman Estates,
Illinois
Boostin Performance 1990-99 DSM & Evo 1-3 Manual Transmission Billet Bearing Housing!!
Sick of breaking 4th gear? Whether you're using OEM gears (Evo 3), Liberty's Gears Face Plated option, or an aftermarket gear-set like Pfitzner Performance Gearbox - PPG, this is something that everyone making power through a manual transmission can benefit from.
- Keeps the bearing pre-load consistent, even when the transmission case is under heavy load.
- Keeps the shafts and gears in proper alignment under severe lateral load. (Like seen with helical gears)
- Increases transmission case rigidity.
- Will not break or crack the intermediate shaft bearing retainer, which is a weak point on the OEM unit. (See images 5 & 6)
- Running helical gears? We recommend this at or above 500+WHP.
- Running straight cut gears? We recommend this at or above 1,000+WHP.
- Plus, it looks badass!
The OEM gears are getting expensive and hard to find....and PPG gear sets are not cheap either. Our BP Manual Trans Billet Bearing Housing is a great way to help protect your investment!
Contact us to reserve your unit now, as we're only producing a small number of these.
**INTRO PRICE FOR FIRST 15 UNITS SOLD** $789 + shipping
Regular price - $889 + shipping
Deposit of $400 due when reserving a unit
