Please Support STM Tuned
Please Support ExtremePSI
BogusSVO- How to links and other info.
General Knowledge
*How to figure Compression Ratio
*Engine Machine work explained – written by Big Woo
*Delta "HKS272 Regrind" Info. – written by bastarddsm
Cylinder Head
*4G63T Head oil port mod
*Oil port mod #2 for the 4G63t
*1G head flow numbers and intake designs...long – written by Polk
Valve Springs
*4G63T Valve spring Info
*Valve spring comparison- Stock, HKS, BC1100
*Valve spring comparison #2 - Evo VIII, Stock DSM, Manley, Brian Crower
*Checking 4G63 Valve Springs
Camshaft
*How to figure a camshaft's lift
*Camshaft Identification Information
*Camshaft basics and Understanding – written by keltalon
This is info on how some cams perform, along with member views.
*Cam test: I will be dyno test: delta hks 272, delta K272 and BC 272 cams!!!!
Head Building
*How to Have a 4G63 head rebuilt.
*4G63 Head build- Modified
*4G63 Dropped Valve Head Repair
Head Machining
*How to Test Valve springs
*Why NOT to let your head be Belt Surfaced
*How to Surface a 4G63T Cylinder head for a MLS head gasket
*How to check a head for warp
*Why to have your Valves back cut
*How to lap a valve
*How To measure a 4G63 for Cylinder Head for Thickness
*How to change Valve guides In a 4G63T head
*How to replace seats in an aluminum Head
*How to CC a Combustion Chamber
*How an Aluminum Head is pressure tested for cracks
*How to clean a Head Gasket Surface
*How To Fluid Test a 4G63 Cylinder Head
*Turbo oil feed port repair
Short Block
*How to check piston to deck clearance
*How to deck a 4G63 Cast Iron Block
*4G63T Block Correction Machining - Belt Surfaced Block
*How to Fix,Balance and hang Pistons
*Forged, Cast or Hypereutectic Pistons? The Choice is Easy When You Know!
*How to R&R press fit pistons and balace rods 6bolt 1g 4G63
*How To Final wash an Engine Block
*Head gasket Repair- How to clean the block deck with the pistons installed.
*How to Measure, Mic, a Piston
*How to check for pinched or bad rings.
*The worst block I have ever surfaced!!
*4G63 Block oiling Mod
*Manley Piston Inspection
*Cut crank and tested theories. – written by jmelocik
*A look at Stock Rod weights
*Balancing 63DT NPR Pistons
*BSE A look at stubby shafts
*BSE Front Case Prep
*BSE: Bearing Flip
*Pull your Balls to properly clean your Crank
*How to plug crank oil galleys after ball removal
Miscellaneous
*Oil Pressure Relief Valve Porting – written by knochgoon24
*Backyard straight edge
*How to package a head for shipping
*How a Flywheel is resurfaced
*How to lighten a stock cast iron Flywheel
*How to Remove a Broken Bolt
*How to remove bolts that are broken flush. – written by Colt4G63 also
*Broken Exhaust stud repair
*Broken bolt removal - Mixed methods
*How to install a Heil-Coil
*How to destroy a head
*How to repair a Kirban Adjustable Fuel Pressure Regulator
*Replacing the Diaphragm in your AFPR – written by 9!’clipseDOHC
*How to cut open an oil filter and inspect.
*Oil filter cut away Fram & WIX
*How to test an Oil cooler
*How to distinguish 7 bolt head, 6 bolt non-turbo head, & 6 bolt turbo head
*Is this a 2nd gen or 1st Gen head
*Time-sert Installation/Walkthrough on a cylinder head -- written by 99gst_racer
*How to replace lash adjusters / lifters -- written by kenamond
*Question for bogusSVO
