Bender
- 498
- 3
- Aug 22, 2005
Monroe,
Michigan
You can just email me at [email protected] and I can send you a wiring schematic I made to activate full line pressure at WOT only.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Ok, with the TCU completely removed. How would I lower the line pressure? I like how it shifts hard under full throttle but I want to be able to tone it down a bit with either the Pwr/Eco mode switch or at full throttle. Could I get a circuit for that?
That's what I'm aiming for. I'll build everything into an empty TCU case. That way I can use Molex connectors right on the back side of the case for easy center console access. I'm going to assume that I could mess around with 100hz. I'll do that first with a 555 timer. Then maybe four separate pot adjustable MESFET circuits per gear controlling PW based on TP. Assuming still that that is how the TCU does it in the stock environment. Right now it's just in my head.
So I'll have a box that I can manually shift but automatically control line pressure. Then at a predetermined attribute enable full line pressure. I could also tap into the Tach and input/output speed sensors and use a BASIC program control gears automatically. But that is a long time from now. Could possibly use an Arduino to control everything.
TCUGO is exactly what it did right? They are no longer able to be found.
For every 100-150 people that want something only 1 is a buyer.
Once you activate full line pressure electronically, that is all you get. You won't get extra pressure by doing the relay method, in fact, the relay "disconnects" the TCU's PCRS output while it is activated, which is why the resistor is needed (to keep the TCU from going into limp mode.) The only way to get more line pressure is to turn the adjustment screw in the valvebody. If memory serves me correct, it is 5 psi for each full turn.
You won't see those dyno numbers whp wise on an auto. The auto reads (on average) 15% lower on a dyno than their 5 speed counterparts, and this is taken from people swapping from 5 speeds to autos, with no other changes.
If you want progressive line pressure control, David's TCU or IPT's booster are the only ways to go. Well, without reinventing the wheel. I have tossed around a standalone PWM controller, but my car is so harsh driving as it is, it wouldn't make a difference.
No problem. I am hardly ever on this forum, but got bored today and decided to check my discussions. Glad I did.
Sounds like you have no provisions for extra line pressure, and I can almost guarantee you it is slipping at WOT shifts. My advice? Don't drive the car until you address that issue. You will burn your new clutch packs out fairly quickly above 400hp (my benchmark number I recommend to people. I believe Dave's is in that area as well).
What size tranny cooler are you running? If not, get one asap as well with a temp gauge. Those are the first things I recommend when people ask me what they can do to "build" their trans up. After that it is a stalled converter, shift kit/line pressure, and an aftermarket end clutch assembly. Sounds like you have most of that covered. Did IPT build the trans? If so, they put their own shift kit in (they have custom springs wound for them).
The factory TCU with factory code never demands 100% line pressure. I'd have to double check but I don't believe it goes much over 50% ever.
Dave can change the pulsewidth based on TPS so can basically do what ever you would like. Full line pressure at 50% throttle, or even a gradient taper as TPS increases.
Try this instead, [email protected]
I think that there is a misunderstanding on how
