muffinstar16
- 51
- 3
- Apr 30, 2016
Spring Lake,
Michigan
So this morning i get in my 1999 gst and notice my dash lights arent on. Oh well. suns coming up, ill get a new fuse after work. I get new fuses pop one in, start my car and.... blown fuse again. happens multiple times and with every size fuse above a 15. I researched it and still cant tell if its my dimmer switch that needs replacing, im grounding out the circuit or maybe my alternator is going bad. I have done nothing electrically to the car since december and this is the first time its happened. I have an aftermarket deck as well as wiring for subs with a killswitch to use said subs. The previous owner wired in an HKS turbo timer that still works even when my dash lights dont. I have turn signals and headlights, but no dash lights or tail lights. I need this fixed asap as i work 30 minutes away and most of my commute is in the early morning. Any suggestions are Greatly appreciated. I know there are many other posts like this but none seem to have answers. Thank you all!
