TheFlashDSM
Supporting Member
- 1,082
- 312
- Feb 18, 2010
stony brook,
New_York
For my high hp build i bough a ble solid tensioner, i saw it online and jumped to conclusion that it would be best for my build. well im at the stage now where im putting back together my motor. and doing some research i found the ble might not be as good as i thought.
what i know about the ble. please correct if im wrong. HARSH COMMENTS WELCOME!
1. constant checking of belt tension
2. being an iron block and aluminum head when it heats up and they expand it could make belt too tight
3. keeps constant tension on the belt with no belt slap at high rpm
Q. will i be okay with the stock tensioner and tasking a risk of it blowing out, or should i use the ble and always check the belt tension before every race?
please will someone let me know if my track only car will benefit on the track from it or not.
current build... http://www.dsmtuners.com/threads/my-2g-dsm-second-build-this-ones-going-smoother.499369/
