black vacuum box
Posted by OZgsJames, Feb 29, 2012
420A Bolt-on Tech - Intake, exhaust, ignition, fuel system, cooling, etc - specific to 2G N/T DSMs. New Members must limit their 420A tech posts to this forum.
Please Support Boostin Performance
  1. OZgsJames
    OZgsJames Proven Member
    Aug 13, 2011
    32
    Rockland, New_York
    HELP
    mounted my rebuilt 420a the other day and in the the rush of getting it done, i forgot to bolt the small black box with vaccume lines that run into it, now with very little room to get behind the motor (decent amount underneath though), I cant seem to find where it bolts up. And i cant find it on alldata because idk what its called.
    If someone could get me a diagram or picture of where it bolts up on the firewall, that would be greatly appreciated.
    #1
  2. bullettdsm
    bullettdsm N/T DSM Wiseman
    Dec 17, 2004
    2,408
    28
    East Hampton, Connecticut
    Its for your cruise control. There should be two studs screwed into the back of the block, that where it gets put on with two 13 mm(?) nuts.
    MB
    #2
  3. xcasbonx
    xcasbonx Proven Member
    DSM Profiles:
    Oct 10, 2011
    73
    3
    Plymouth, Indiana
    The box is not a necessity. Just re route the vacuum line from the cruise vacuum servo and you should be good to go.
    I pulled my intake manifold last summer to install a phenolic spacer and I didn't bother re-installing the box...and to my surprise my cruise control still works fine.
    #3
  4. Fotowntalon
    Fotowntalon Proven Member
    May 14, 2008
    1,036
    8
    Fostoria, Ohio
    That little black box is more trouble than its worth imo. I'd remove it, but then again I have eliminated my cruise control. Weight savings FTW!!!!
    #4
  5. OZgsJames
    Aug 13, 2011
    32
    Rockland, New_York
    A plastic box gets bolted to the engine block? Tht dnt seem right
    #5
  6. Josh97eclipse
    Josh97eclipse Proven Member
    DSM Profiles:
    Feb 14, 2011
    218
    N. Ridgeville, Ohio
    Dont even bother putting it back on, I also deleted cruise........its useless
    #6
  7. OZgsJames
    Aug 13, 2011
    32
    Rockland, New_York
    i plan on doing long trips in this thing. I want cruise
    #7
  8. 2GCruiser
    2GCruiser Proven Member
    Apr 4, 2011
    73
    East Bethel, Minnesota
    If it is the cruise control you're talking about he meant it gets bolted to the firewall in the passengercorner
    #8
  9. 1g8420a
    1g8420a Awaiting Email Verification
    Nov 19, 2011
    89
    Fort Riley, Kansas
    On the box there is one bolt hole on the top. On the bottom there is 2. The bottom two holes bolt to the block. The one hole faces up top and bolts to the intake manifold and yes 13 mil.
    #9
  10. 2GCruiser
    Apr 4, 2011
    73
    Ignore this I thought you wanted to know where the Cruisecontrol mounted. The box your talking about mounts right under the intake manifold stays. I'm actually pretty sure it's 14 mil but I could be wrong. Like said above its one bolt on top 2 on bottom
    #10
  11. Alan11
    Alan11 Proven Member
    DSM Profiles:
    Apr 30, 2010
    614
    El Paso, Texas
    It bolts up to the two brackest attached to the block and intake manifold..
    #11
  12. OZgsJames
    Aug 13, 2011
    32
    Rockland, New_York
    thanks guys!
    #12
  13. Josh97eclipse
    DSM Profiles:
    Feb 14, 2011
    218
    N. Ridgeville, Ohio
    Still cruise is useless.
    #13
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
