1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
Billet automatic transmission dipstick 2g and 1g
Posted by antilag_200, Jun 5, 2018
Please Support ExtremePSI
Thread Status:
Not open for further replies.
  1. antilag_200
    antilag_200 Proven Member
    209
    31
    Joined Oct 28, 2002
    lansing, Michigan
    Hello folks, just wanted to share a project that I am working on with a few of them out in the wild. They are my vented automatic trans dipsticks for the 2G Trans.
    I was tired of the plastic dipsticks and my 1g dipstick looking ragged, Having a love for billet - this was the end result .
    Features are
    -6061 aluminum
    -vented handle - accept a -4 AN fitting
    -provision to add safety wire/spring to lock the dipstick in place
    -new lokar "dipstick" incorporated into the handle.
    I released them on facebook and have sold the first batch of 2g ones there.
    Mods if this is the wrong space to write this - feel free to let me know and I will remove it .Thanks for the space.
    warren
    Log in/Register to remove ads
    My DSM:
    1990 Mitsubishi Eclipse GST
    10.361 @ 142.490 MPH
    Loading...
    MorrisonFab and turbotalon1g like this.
    Featured Products from our Supporting Vendors
  2. turbotalon1g
    turbotalon1g Proven Member
    801
    30
    Joined Oct 19, 2005
    Blaine, Minnesota
    Does the trans really need venting? Honest question, my car hasn't run in 3 years so I'm clueless.
    Can you get a close up shot of the dipstick/measuring portion? That was always a bi*** to read.
    Thanks for making these, they look awesome.
    My DSM:
    1991 Eagle Talon TSi AWD
    Drag Race Build
    11.333 @ 119.94 MPH
    Loading...
  3. Boomdeeze
    Boomdeeze Proven Member
    1,472
    178
    Joined Jul 5, 2009
    Independence, Minnesota
    What are you running the line to for venting? Open? Have you noticed any difference?
    My DSM:
    1997 Mitsubishi Eclipse GSX
    Street Build
    10.793 @ 128.98 MPH
    Loading...
  4. infam0usdeed
    infam0usdeed Proven Member
    54
    5
    Joined Nov 20, 2012
    North Las Vegas, Nevada
    Where is it being vented to? Sure is a pretty piece.
    My DSM:
    Loading...
  5. ec17pse
    ec17pse Freelancer
    2,969
    965
    Joined Nov 1, 2008
    London, Europe
    It dont need venting, also you see the hose off the side of the main tube body, thats similer and goes back into the pan, while the item looks good i see no benefit in this,
    Please do explain the development as to why you made it though, always good to understand others research in the group
    My DSM:
    1997 Mitsubishi Eclipse GST
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  6. TSIMonsteR
    TSIMonsteR Proven Member
    1,361
    14
    Joined Nov 23, 2003
    HP, North Carolina
    Looks great! I'm also nieve to the venting requirement. Pros and Cons?
    My DSM:
    1998 Mitsubishi Eclipse GSX
    324 whp   256 lb/ft
    Loading...
  7. antilag_200
    209
    31
    Joined Oct 28, 2002
    lansing, Michigan
    Thank you for the interest -
    The stock dipstick tube itself is vented . If you look at the top of your tube in a 1g for example you will see a tiny hole there . When your trans is operational the fluid will aerate as the gears and components in there turn. The factory set up allows for this.
    In my case and my car I had fluid come out, which ended up getting on my tire during a pass . Definitely was not a fun ride. Thus I decided to make my own dipstick.
    I am attaching the top of the dipstick to a vented catch can . Another reason why I made this was because I was tired of looking at the crappy stock dipstick (all yellow and old) so more of a vanity portion on that aspect . Hope that helps
    My DSM:
    Loading...
    turbotalon1g likes this.
  8. antilag_200
    209
    31
    Joined Oct 28, 2002
    lansing, Michigan
    IMG_E7920.JPG IMG_E7921.JPG Here are some pics from a car in california
    My DSM:
    Loading...
  9. jls_frog
    jls_frog Supporting Member
    101
    11
    Joined Sep 15, 2011
    plano, Texas
    If no catch can is connected. How much fluid comes out?
    My DSM:
    Street Build
    241 whp   252 lb/ft
    Loading...
  10. antilag_200
    209
    31
    Joined Oct 28, 2002
    lansing, Michigan
    In an ideal world no fluid should come out. In my case when the fluid came out once- I think it was a situation of overfilling ( even though the mark was on the dipstick)
    A standard size catch can should suffice.
    My DSM:
    Loading...
  11. antilag_200
    209
    31
    Joined Oct 28, 2002
    lansing, Michigan
    Making a run of these folks, let me know if you are interested so I can add your name to the list . please specify if you want 1g of 2G
    My DSM:
    Loading...
    Dstarperformance01 likes this.
  12. Dstarperformance01
    Dstarperformance01 Proven Member
    711
    129
    Joined Mar 5, 2016
    Mustang, Oklahoma
    If a transmission doesn't need to vent, then why do they have vents on top of automatic transmissions and rear differentials?
    My DSM:
    1993 Eagle Talon TSi AWD
    Street Build
    16g   automatic
    Loading...
    antilag_200 likes this.
  13. ec17pse
    ec17pse Freelancer
    2,969
    965
    Joined Nov 1, 2008
    London, Europe
    I ment it more for the fact he will be using a catch can as i guess this from the start which means he will be pulling the air out, so while it vents naturally pulling the air out is not the best idea as if it sucks too hard it might pull the fluid up, so thats why i commented, fair enough i should have perhaps worded it alot differently
    My DSM:
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  14. antilag_200
    209
    31
    Joined Oct 28, 2002
    lansing, Michigan
    there isn't any "drawing" of air through the tube. It is just A larger path than what is already there in factory form. At least in my experience.
    the catch can is more safety in my case - because going into the wall is not an option for me or anyone else for that matter .
    cheers
    My DSM:
    Loading...
  15. Dstarperformance01
    711
    129
    Joined Mar 5, 2016
    Mustang, Oklahoma
    Lol, after I read it like 5 times thought maybe that's what you were referring too.
    My bad:heystupid:
    My DSM:
    Street Build
    16g   automatic
    Loading...
  16. ec17pse
    ec17pse Freelancer
    2,969
    965
    Joined Nov 1, 2008
    London, Europe
    Haha nah man i word things badly sometimes, plus i dont know if i wrote this when i woke up or not as i do that often so i am not always great at getting my point across well LOL,
    My DSM:
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  17. Dstarperformance01
    711
    129
    Joined Mar 5, 2016
    Mustang, Oklahoma
    Same here :ohdamn:
    My DSM:
    Street Build
    16g   automatic
    Loading...
  18. ec17pse
    ec17pse Freelancer
    2,969
    965
    Joined Nov 1, 2008
    London, Europe
    while we appreciate the offerings you bring you have to follow the sale rules im afraid, it has to be sold in the classifieds section and not in a thread! also as its more then 1 im not sure if this falls under the rule of freelancer or not since its a product your offering and not a 1 off. maybe a mod will chime in and know whats best
    but not getting at you just helping you avoid getting banned or something from breaking the rules here as we all have to follow them to keep it better for everyone
    My DSM:
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  19. JusMX141
    JusMX141 Moderator
    12,702
    688
    Joined Dec 13, 2005
    Greensburg, Pennsylvania
    Closed, classified content removed. Sign up to be a Freelancer for selling products/services to the community; the tech forums are reserved for tech help and not parts peddling / individual transactions.
    Loading...
Thread Status:
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
