Bent valves?how can I tell
Posted by 90tsiawdturbo, May 25, 2010
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support Ace Race Parts
  1. 90tsiawdturbo
    90tsiawdturbo Proven Member
    Apr 23, 2010
    321
    New London, Wisconsin
    Is there a way I can tell if my valves are bent with out taking my head off...I kno one piston and/or rings are bad but I still gotta be able to possibly drive it 15 miles to the shop so I don't want to take the head off... Any suggestions?
    #1
  2. Derock2gspyder
    Derock2gspyder Proven Member
    Jun 24, 2008
    48
    spanaway, Washington
    compression test! check the compression and see a bent valve will leave the compression very low or at 0!
    #2
  3. 90tsiawdturbo
    Apr 23, 2010
    321
    Like I said I have a bad piston so I know there's bad compression in that cylinder....is there any other way?
    #3
  4. woomer
    woomer Proven Member
    Dec 18, 2006
    109
    huntingdon, Pennsylvania
    just about every time you bend a valve - even if your saying your pistons are bad - it still should have compression even if its low ------ with a bent valve you will have zero compression --------a compression check is basicly the only way of telling short of pulling the head and getting a shop to check it - zero compression is a sure tell sign of a bent valve :nono:also if you have a very severe miss ....even at idle --and loss of power --- but run a compression check sure fire way
    #4
  5. DeadsEvolution1
    DeadsEvolution1 Proven Member
    DSM Profiles:
    Jan 10, 2008
    347
    Albuquerque, New_Mexico
    I agree, you need to run a compression test. If you do infact have a bent valve the cylinder should be at 0 compression when testing. Read the Vfaq if you do not know how to do the test.
    #5
  6. donniekak
    donniekak DSM Wiseman
    DSM Profiles:
    Mar 23, 2008
    4,108
    511
    Surprise, Arizona
    Pull the valve cover and look for loose rocker arms. Do a leakdown test.
    #6
  7. 90tsiawdturbo
    Apr 23, 2010
    321
    Ok thank you guys very much for the help I appreciate it a lot!!
    #7
  8. spoolin ddub
    spoolin ddub Proven Member
    DSM Profiles:
    Aug 24, 2007
    540
    15
    Chicago, Illinois
    A compression test is good but it just shows that a problem exists. Do a leak down test so you can pinpoint the exact source of the compression loss. You say one piston and/or ring is bad. You may have more than one problem. You could have 0 compression from a bent intake and/or exhaust valve and then on top of that have a bad ring in that same cylinder. A compression test won't pinpoint that. It's best to do both test.
    #8
  9. 90tsiawdturbo
    Apr 23, 2010
    321
    Well I'm showing low compression in that cylinder not zero compression
    #9
  10. BogusSVO
    BogusSVO Proven Member
    Jul 1, 2009
    5,711
    259
    Pensacola, Florida
    #10
  11. spoolin ddub
    DSM Profiles:
    Aug 24, 2007
    540
    15
    Chicago, Illinois
    The only way to know for certain what it wrong is to do a leak down test.
    #11
  12. JusMX141
    JusMX141 Moderator
    DSM Profiles:
    4
    Dec 13, 2005
    12,573
    531
    Greensburg, Pennsylvania
    Pull the valve cover. If any of the lifters seem to be out further than normal, or if any of the rockers are loose you have bent valves on that cylinder.
    [​IMG]
    But again, if you have obscenely low compression on any cylinder chances are you have at least one bent valve. If even one valve is not sealing properly, it will result in "0" compression for that cylinder. While rebuilding a buddy's 1G a while ago, he had two cracked exhaust valve guides on cylinder 1 which resulted in "0" compression....the valves were not even bent.
    #12
  13. 90tsiawdturbo
    Apr 23, 2010
    321
    Ok thanks guys!! Don't know what i'd do without you all!!
    #13
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
