Bell housing crack [Merged 2-9]
Posted by ONR, Apr 25, 2003
Drivetrain Tech - 4G63 transmission, clutch, flywheel, driveshaft, gears, differentials, transfer case, shifter, etc.
Please Support Jackson Auto Machine
  1. ONR
    ONR Proven Member
    Mar 12, 2003
    40
    , CaliforniaUS
    Can i just weld this back together...with the proper welding of course or should i just suck it up and buy myself a new bell house/tranny, its about i woudl say 6" long and then has anotehr lil part about 1" off that...and is there anywhere in northern/bay area cali that i can pick one up at?....Thanks
    #1
  2. candela
    candela Proven Member
    DSM Profiles:
    May 10, 2002
    3,367
    Austin, Arizona
    If it were me, Id just weld it...
    #2
  3. Defiant
    Defiant DSM Wiseman
    DSM Profiles:
    Jan 13, 2003
    25,202
    112
    glorious Galt, California
    My god, what have you been doing? Try All Foreign in Berkeley, or check around in the classifieds here and eBay.
    #3
  4. miguels3000
    miguels3000 Proven Member
    Mar 31, 2003
    225
    Los Angeles, California
    No man just changed the bell housing, buy a core and switch over the insides. Youre going to spend the same.
    #4
  5. ONR
    ONR Proven Member
    Mar 12, 2003
    40
    , CaliforniaUS
    thats what my dad wants to do is just weld it cuase its the bell housing and thats free oposed to buying a new tranny/bell housing...and i know my throw out bearing is shot...and my clutch is not grabbing/disengaging properly so i can work on that while thats all off...
    #5
  6. miguels3000
    Mar 31, 2003
    225
    If youre car is awd and you have alot of mods, I would change it, because the integrity is already broken. and with all that force that is going on in there i wouldnt want to risk anything else happening. but i guess you could weld it if you wanted to. And mainly its free.
    #6
  7. ONR
    ONR Proven Member
    Mar 12, 2003
    40
    , CaliforniaUS
    the car is stock so i dont really have to worry about that yet...i plan on doing alot of stuff but for the time being i just wanted to be able to drive myself around town...and i will within a couple months when i start moding figured id buy a new tranny any ways just for fun...you konw just have it as a spare...ill have to check out that "all foreign" place out in berkely...
    #7
  8. RipperXX
    RipperXX Proven Member
    DSM Profiles:
    Feb 23, 2003
    2,981
    47
    Royston, Georgia
    well i found out what that disturbing pop was when i was bolting it back on.. a wire clamp got inbetwine the motor and trans bell houseing.. it made a 2 1/2" crack down the side of it....
    can this hurt anything???
    #8
  9. allwheelTSI
    allwheelTSI Proven Member
    DSM Profiles:
    Sep 9, 2002
    1,486
    5
    Hendersonville, North_Carolina
    it can snap off and your transmission can fall out!!
    eh,i don't know what could happen..
    #9
  10. turbolover2
    turbolover2 Proven Member
    DSM Profiles:
    Oct 5, 2002
    338
    Long Island, New_York
    Chances are that it would be ok. But, to be on the safe side, you might want to have it welded.
    #10
  11. RipperXX
    DSM Profiles:
    Feb 23, 2003
    2,981
    47
    Royston, Georgia
    well after talking with my dad about it im going to get it welded when i get the engine rebuilt but it poped again which at that moment i was thinking GAWH DAMN IT!!!! but it actuly went back into place and you can't see the crack anymore...
    #11
  12. NVmyRST
    NVmyRST Proven Member
    Jan 18, 2003
    , Lenexa_Kansas
    to make the long story short... blew up a motor, put on new head, and another block i had in my car... all ran fine for 3 days. Heres what happend:
    on the 3rd day, the clutch started to feel like jello. So we thought it was the slave cyl, replaced it... still not working. but at the same time, there was this horrible squeeling noise, figured it was the throw out bearing. Went to replace that and realized the bell housing was cracked under the top hole on the intake side of the tranny, towards the exhaust side. Also the top hole on the exhaust side is completely broken off, on the bottom of the block on the exhaust side the ear is broken off.
    Now when it was taken apart, there are not marks on the flywheel, pressure plate, disc or input shaft.
    The one odd thing is that the line up pins that are in the block are now stuck in the tranny.
    What would have caused this to happen? Any ideas are greatly GREATLY appreciated. Just a little background in case anyone needs to know, ACT 2100, RRE Lightened flywheel, and a new transmission. And i hope this makes sense... as to i am about to go insane....:mad:
    #12
  13. CleanGS97
    CleanGS97 Proven Member
    DSM Profiles:
    Dec 5, 2002
    70
    , Lawrence_Kansas
    maybe it got "clutchwalk" .,..:( honestly im as lost as you.
    #13
  14. Defiant
    Defiant DSM Wiseman
    DSM Profiles:
    Jan 13, 2003
    25,202
    112
    Clutch housing bolts hadn't been torqued and worked loose.
    #14
  15. Phil Sochor
    Phil Sochor Proven Member
    Oct 31, 2002
    36
    Rochester, Michigan
    Hey I have a 92 AWD 5-speed trans sitting around over here with a cracked bell housing (the part that bolts to the engine block) and with some huge chunks broken off it. I was wondering what year trans I could pull off another bell housing and bolt it up?? Any info would be nice. Thanks.
    #15
  16. Phil Sochor
    Oct 31, 2002
    36
    Rochester, Michigan
    Does anyone know anything about this???
    #16
  17. boostedinaz
    boostedinaz DSM Wiseman
    DSM Profiles:
    Dec 22, 2002
    2,320
    14
    Scottsdale, Arizona
    You should be able to use one off any 1G trans as long as they are the same IE FWD AWD. The only difference that i can for sure say is the 90 have different levers and spline count.
    Michael
    :laser: :talon:
    #17
  18. 1gGSXboostin
    1gGSXboostin Proven Member
    Mar 25, 2004
    10
    Mount Prospect, Illinois
    Ok,
    heres the problem
    Recently the bolts connecting the bell housing to the block came loose..Making it hard to put into gear and it was grinding into the gears. I tigtened them up and all was fine..until yesterday, when I realized this was happening again. I looked uder the hood and car and all the bolt were tight. Then I realized that by the bolt that is closest to the bottom motor mount, the block was cracked right after the bolt and that the bell housing was shifting because of that everytime I pushed in the clutch. So a mechanic thinks that it can be welded, I need to know if this is possible. He is talking about welding the crack and then welding a plate to the motor mount w/ a 90 degree angle to the bolt and thread the bolt through the holein the plate and back into the block. This may be hard to understaand. I would like to know any input..
    #18
  19. krosTSI
    krosTSI Proven Member
    DSM Profiles:
    Mar 28, 2003
    191
    , OregonUS
    Allright, ever since i put in my ACT 2600 my gears would grind like crazy and never go into gear. I snooped around and realized that 2 bolts were extremely loose from my bell housing to my block I tightened them up and the problem was resolved. But it keeps on coming back. there always coming loose, bolts arent stripped or anything just like they unthread themselves. Im think there is alot of flex between the B.H. and block that is causing this. also my pedal feels real sloppy no pressure. any one have a clue? :confused:
    Thanks,
    -Ky
    #19
  20. PogiTSI
    PogiTSI Proven Member
    Aug 9, 2003
    247
    WPB, Florida
    its possible that there streched. try getting some new bolts, and see if that helps. also are your torqueing those monsters???? ALSO are you sure you got all the bolts in on the bottom???????
    #20
  21. fivestardsm
    fivestardsm Proven Member
    DSM Profiles:
    Aug 16, 2002
    500
    , Morley_Michigan
    Also, use some lock-tite on the threads.
    Have you recently had the timing belt replaced? It sounds like you might be getting some vibration that may be causing your bolts loosening. I had a problem on a car I picked up and the rear balance shaft was 180 off and causing vibrations that the seller though was bad bearings. Its bolts were coming loose in the bellhousing from that. :rolleyes:
    Steve.
    #21
  22. krosTSI
    DSM Profiles:
    Mar 28, 2003
    191
    , OregonUS
    I use lock tight every time and I torque them down to specifications and i just had my timing belt done 10,000 miles ago. Still dont know why, I'm gonna go out and do a lot of steps to it. Check the slave cylinder, master cylander, mess with the pedal assembly, adjust the something rod. hopefully i figure this out soon can drive it any where.LOL
    thanks alot guys,
    -Ky
    #22
  23. krosTSI
    DSM Profiles:
    Mar 28, 2003
    191
    , OregonUS
    hmmm
    #23
  24. 95TalonTuner
    95TalonTuner Banned Member
    May 4, 2004
    93
    Well for future reference, you should get new bolts and use Locktite.
    #24
  25. krosTSI
    DSM Profiles:
    Mar 28, 2003
    191
    , OregonUS
    how many bolts go into the block from the bellhousing?
    #25
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
