Battery in the trunk where should i ground it ?
Posted by talon187, Apr 13, 2008
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support Race Components Inc
  1. talon187
    talon187 Proven Member
    Feb 11, 2003
    1,002
    torrington, Connecticut
    ok i got a taylor battery box and i had 4 gauge wire from the trunk to the battery when it was up front for my amps. so i mounted the battery box in the trunk used the 4 guage wire for my power that i already had. I used the sturt mount in the trunk for a ground. Now i have a problem the car doesnt like to start or if it will it really weak untill it does start. I know its the ground. is there a better place to ground? i was thinking of drill into the sheet metal and go trew that into the frame is that a good idea or no ? now that any input would be great
    #1
  2. absolute_DSM
    absolute_DSM Proven Member
    Jan 29, 2006
    1,552
    6
    Boise, Idaho
    If youre having that much of an issue because of it, you probably need to run the ground all the way up to the block and ground it by the starter.
    I ran a 2 AWG from the block to the fuel pump area ground, then to a ground a foot from the battery, then connected it to the battery.
    #2
  3. super97gst
    super97gst Proven Member
    Nov 18, 2004
    373
    10
    Clinton, Kentucky
    you need to ground as close to the battery as possible. the ground lead doesn't need to be any longer than 18-24". all you need to do is drill a hole through the sheetmetal in the floor, and bolt the ground lead down with flat washers on both sides of the bolt. you could also use a lock nut, like an ultra ss lock nut so you dont have to worry about it working loose. your ground needs to be the same diameter or larger than you power lead. also, it would be a really bad idea to run the ground a long way to the front of the car for the fact that the longer the ground the less effective it is. it creates less resistance for every foot longer it is. make sure you take a grinder or emery cloth and take all of the paint off in a 1 or 2" area around the spot you're gonna drill the hole for the ground.
    #3
  4. Pasquin
    Pasquin Probationary Member
    DSM Profiles:
    Feb 24, 2008
    28
    West jordan, Utah
    i grounded mine on the strut tower and never had any problems but maby do a load test on your battery see if it's still good
    #4
  5. talon187
    Feb 11, 2003
    1,002
    battery is good because when i put the charger on it was almost a full charge this only started when i put the battery in the trunk hrmm
    #5
  6. illeffekt vr-4
    illeffekt vr-4 Proven Member
    Sep 26, 2004
    262
    NYC, New_York
    Try scraping the paint off to get a better contact.
    #6
  7. talon187
    Feb 11, 2003
    1,002
    yeah i did that not so great....
    #7
  8. absolute_DSM
    Jan 29, 2006
    1,552
    6
    Boise, Idaho
    I dont think I was descriptive enough.
    I have 3 major grounds throughout the car, soon to be 4 (one by the ECU).
    I have a lead from the battery then bolted to the frame. (Main battery ground - about 12" long) Then I ran a lead from that same ground up to the passenger side by the fuel pump. Then I ran the last lead from that same spot on the passenger side up to the engine bay and bolted it to the block. It essentially connects all the grounds from the block to the battery.
    #8
  9. 92awddsm
    92awddsm DSM Wiseman
    DSM Profiles:
    Jan 17, 2004
    3,934
    79
    Chesterfield, Virginia
    The 1g has child seat harness mounting locations in the trunk that go through the frame. This is the perfect location to use as a ground.
    #9
  10. talon187
    Feb 11, 2003
    1,002
    sweet ill try that my luck went from bad to worse today :(
    #10
  11. slowgsr
    slowgsr Proven Member
    Dec 17, 2007
    798
    6
    hamilton, ON_Canada
    ground it to the block, and from the block to the chassis at the front, you can ground it in the rear also.
    Our unibody's are not good conductors, its beyond me why people just run the ground to the sheetmetal in the rear.
    Proper electrical is so important, your not wiring up a trailer hitch, your wiring up a complex EMS system.
    #11
  12. lasthope05
    lasthope05 Proven Member
    Mar 31, 2006
    633
    110
    Philadelphia, Pennsylvania
    Grounding your car to the chassis works perfectly fine a lot of people. I just grounded mines on one of the trunk latch bolts. Im running 2gauge also.
    #12
  13. secondnature
    secondnature Proven Member
    Jul 3, 2004
    93
    fredericksburg, Virginia
    I also grounded mine in the same place and have had no problems
    first pic is of a breaker box that is for the + side going to the starter and to battery
    And the second pic is where i have my ground
    #13
  14. super97gst
    Nov 18, 2004
    373
    10
    Clinton, Kentucky
    that sounds like an excellent grounding setup.:thumb: i thought you were saying you just ran your ground all the way back to the front. that would be bad.
    btw, as for grounding through the sheetmetal in the rear. it was stated above that shouldn't be done, the electrical system is too sensitive. i worked at a car audio shop for a couple of years while i was in college and we did a lot of battery relocations for people wanting a second battery mainly. anyways, i always installed the ground cable through the rear floor, into the sheetmetal. as many of them as i did i never had one complaint later. those systems must have been a little less sensitive.:D i just always found that was the easiest and a very effective way of grounding a battery in the rear of a car.
    #14
  15. 92awddsm
    DSM Profiles:
    Jan 17, 2004
    3,934
    79
    That is the reason for grounding at the child seat bracket mount. This is actually into the subframe and not just the sheet metal. As long as mine has been grounded this way(3-4yrs), I have never had a glitch, issue, or slow starts.
    #15
  16. super97gst
    Nov 18, 2004
    373
    10
    Clinton, Kentucky
    i agree 100%, that would be an excellent spot to ground in a 1G. but a 2G doesn't have that option. and if you stretch all the way to the strut tower in a 2G you're stretching too many feet to be ideal.
    #16
  17. 92awddsm
    DSM Profiles:
    Jan 17, 2004
    3,934
    79
    Sorry, my bad. I forgot, 1g vs 2g.:shhh:
    #17
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
