1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
2G Bad Throwout Bearing?
Posted by JayB12, Apr 23, 2011
Please Support Boostin Performance
  1. JayB12
    JayB12 Proven Member
    465
    Joined Jan 12, 2009
    Philipsburg, Pennsylvania
    I have a 97 gst with an act 2100 (installed by previous owner) about 2 months ago every once and a while I would hear a knocking noise. I thought it was a pulley, so I changed my t-belt and pulleys ect. (needed done anyways) and its still there. I noticed today that the noise will go away with the clutch pressed in. Also there is a constant chirping/high pitched noise in the engine bay. And the last symptom I have that may be related is an odd clicking as I accelerate through first gear (only until ~3k rpms) I'm pretty sure it's the throwout bearing now. I just wanted to be sure though I don't want to pull the trans and that not be the problem.
    Another thing, If it is the throwout bearing I will order an OEM one but I've not really positive on what clutch. I was thinking of the ACT 2100/ Fidanza Flywheel combo on exreme psi but I would like some suggestions as well.
    Log in/Register to remove ads
    1992 Eagle Talon TSi AWD
    10.59 @ 138.25 MPH
    1991 Mitsubishi Eclipse GSX
    12.049 @ 128.28 MPH
    Loading...
    Featured Products from our Supporting Vendors
  2. cliffkemp
    cliffkemp Proven Member
    370
    6
    Joined Apr 19, 2010
    carrollton, Georgia
    Most performance clutches have a chatter to them to an extent. My talon and rx8 have that and the 8 is stock. This covers the chatter noise that stops when you push in the clutch as that is normal.
    As for the other noises, the second may be your crank shaft pulley, if stock, trying to separate. Check it to see if the large pulley part (alternator) is seperating from the smaller pulley. If it is, get a different one as the stock is a poor design and will keep doing this over time.
    The last noise, I am not sure of and could be caused, in part by the second noise. Hard to say unless there in person and see/hear it.
    I am not saying your TB is good or bad as it could be going bad. The chatter is normal with that kind of clutch system. The 3rd noise could be the TB.
    The first is normal to an extent. The second could be the crank pulley or a pulley going bad on one or more of your accessories (if belts were too tight at one time or another) Last could be the TB but, unless you take out the trans, cannot really say for sure. If you are going to drop the tans, replace it anyway and check your fork, fork pivot ball, and tangs that hold the TB as well. Replace any bent or worn parts as needed and do it right the first time. :)
  3. JayB12
    465
    Joined Jan 12, 2009
    For the first noise I have read that it is normal to have noise to an extent but This noise I have is every once and a while. It's a loud knocking you can hear from 4-5 feet away. I also heard that ACT TOB's are known to be junk, and that's what is in there.
    10.59 @ 138.25 MPH
    12.049 @ 128.28 MPH
    Loading...
  4. cliffkemp
    370
    6
    Joined Apr 19, 2010
    carrollton, Georgia
    Sounds like it could be the TB. One way to find out. I would put a stock one in. Did you check your balancer/pulley?
  5. JayB12
    465
    Joined Jan 12, 2009
    I'm not entirely sure how to do that. :|
    10.59 @ 138.25 MPH
    12.049 @ 128.28 MPH
    Loading...
  6. 98mitsubishigst
    98mitsubishigst Proven Member
    918
    14
    Joined Nov 17, 2008
    Pittsburgh, Pennsylvania
    it's the throw out bearing my friend... I have the SAME exact EVERYTHING that you just explained..
    I have a aftermarket clutch/TOB setup, and the TOB is junk..
    But also there is a little clatter because of it being a aftermarket clutch as well.
    Loading...
  7. Anthony Boni
    Anthony Boni Proven Member
    88
    Joined May 13, 2018
    Minot, North Dakota
    Ooooold thread but I'm hoping someone will see this. Having the chirping/rattling noise same as OP. Sound goes away when clutch is pushed in. It sounds like a CHCHCHCHCHCHCHCH noise. Car only has idle time with a 6 puck clutch in it (unsure of the brand, bought from PO with it). Thanks!
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
