bad Throwout bearing symptoms
Posted by initialRES, May 20, 2005
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support Boostin Performance
  1. initialRES
    initialRES Proven Member
    Oct 27, 2003
    64
    Fort Worth, TexasUS
    I've searched like crazy on this subject but can't find an answer so here's my problem.
    I have a Comp 4 puck clutch with their metal sleeved TOB that comes with the disc. The disc was replaced in January, and the throwout bearing was replaced in november with maybe 10,000 miles (long story). It has worked pretty well, however every once in a while it will be very difficult to shift into first from neutral but if I keep driving, it will usually go back to normal. I chalked it up to a fluke (I already changed the fluid and bled the clutch lines). Anyway, I noticed a while ago that it would make a faint whirring noise at idle that went away when I pushed in the clutch. I figured this was just the metal throw out bearing.
    Tonight I noticed that if I am coasting at like 30 mph and take it out of gear, when I stop, the whirring noise is louder than at idle. If I push in the clutch, It goes away. When I release the clutch again (still stopped), the noise is quiet like it usually is at idle. I assume that it is the throw out bearing but I don't know if this is normal or not. I did notice, that this morning, when the car was not driven hard, it did not make the louder noise after coasting to a stop. I am just worried because I have to drive it 500 miles this next week and I am terrified that it will break on me, which it has done before (hence the strange replacement history). I also do not want to pull out the tranny this week if this type of noise is normal. My question is what are some signs of a bad throwout bearing?
    By the way, I have no problem shifting other gears when first gets notchy. Others shift just fine. There are also no other noises that occur, just the notchy noise in first gear sometimes, and the whirring noise. Any help is appreciated. I hate pulling my tranny so I'd like to avoid it, but if you guys think that it could fail or damage things within the next few months, I'm going to pull it apart this weekend. Thanks in advance
    #1
  2. Gary 420A RS
    Gary 420A RS Proven Member
    Jul 7, 2003
    578
    9
    Oxnard, Ventura, California
    when a throw out bearing starts to go bad..
    usually its just the clip connecting the throw out bearing to the fork itself. but you'll hear a rattling everytime you disengage the clutch or when your engaging it at that. it costs in the ballpark of 45$ so replacing that before it effects your clutch is a benefit in your pocket itself. but you will notice the lack of pressure it usually has.
    #2
  3. FourG63 97GST
    FourG63 97GST Proven Member
    DSM Profiles:
    Jul 21, 2002
    1,455
    3
    West Palm Beach, Florida
    when mine went bad, I felt alot of vibration in the pedal everytime I push the clutch pedal in
    #3
  4. taylorspl
    taylorspl Proven Member
    Nov 3, 2002
    231
    Tucson, Arizona
    List price @ the dealer is ~$32. I called today because I have to do mine this weekend.
    #4
  5. 96whgsx
    96whgsx Proven Member
    Sep 28, 2004
    393
    6
    San Francisco, California
    I don't know if this is the same but when my TOB was going out on my miata, it made a noise similar to that of a cricket, more squeaky though, whenever I had the clutch out. With the clutch in, it would stop. Same situation as you but different sound. BTW, the TOB I had was metal.
    #5
  6. Silverbolt_2003
    Silverbolt_2003 Proven Member
    Dec 14, 2004
    31
    Costa Mesa, California
    U will know if the TOB is bad. On my S-10 when the TOB went out. U could feel it in the petal and u also heard metal swirling on metal. It sounds really bad. Jack it up and listen to it. If it is a swirling metal sound then it is bad. Plus i thought using metal splined TOB was bad for the input shafts. I read somewhere in the forum that u should only use OEM because they are plastic splined.
    #6
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
