bad o2 sensor?? but no cel
Posted by dmak, Jul 22, 2005
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support Kiggly Racing
  1. dmak
    dmak Proven Member
    DSM Profiles:
    May 17, 2003
    97
    edmonton, Alberta_Canada
    So after i install a dp and take out the cat, the o2 reading on my af gauge is ####ed. Now it only reads lean all the time. sometimes it doesn't even light up. So i did some search, and find that it might be the o2 sensor. But my check engine light never come on.
    So, is it my sensor not working? or something else?
    When i go to the part stores in edmonton, they all come up the same bosch sensor. The problem is the wire is way too short.
    should i get one from dealer?? what can i do?
    I also want to know, would a leak between the o2 hosing and the dp give me a lean reading like this??
    help plz
    ps: don't need to tell me how useless the af gauge is, coz i am not using it for tuning, i am not that stupid. i just have it coz there are some light, and i can know if my o2 sensor is working right or not. and i know my wiring is good, coz it worked for the pass yr.
    thx
    #1
  2. ChrisFlo
    ChrisFlo Proven Member
    Aug 29, 2004
    308
    Tucson, Arizona
    Do you have a logger? If so, what is that reading?
    #2
  3. dmak
    dmak Proven Member
    DSM Profiles:
    May 17, 2003
    97
    No, don't have a logger.
    the car only has a dp, no cat, hks filter, bov, mbc, that's all i got
    #3
  4. SoonToBeDSM06
    SoonToBeDSM06 Proven Member
    Oct 17, 2004
    164
    5
    Fort Wayne, Indiana
    I had the same problem dude. My A/F gauge read lean all the time when i bought the car and when I took the o2 sensor out it was covered in black sut. I knew that it was gone when i read it with my multimeter as well. It kept reading .25 volts even when i reved it. I went to Advance auto and bought a Bosch o2 sensor for a 95 Eagle Talon. Well the wire was too short and the plug didn't fit. So i searched the net and found a Denso sensor for $70 shipped and that solved the problem.
    P.S Mine never gave a CEL either. Plus the denso handles race gas better than factory ones. Says that on the MachV website. Come back if that solves the problem
    #4
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
