Vicecreed
- 38
- 4
- Apr 19, 2015
Burnsville,
North_Carolina
Pulled a 420a and 5speed transmission out of a 95' Eclipse RS and put it into a 95' Talon ESi.
While in the Eclipse, the only issue I had was when I started the car, I had to give it a little gas for a few seconds for it to idle, other than that it ran fine.
Now after swapping the motor(along with the ECU), it starts and idles fine, but when you first take off in 1st, and while going up even the slightest incline, or when you try to "go fast" it sounds like crap, like its running on three cylinders.
Sounds a lot like a Subaru, the best way I can describe the sound.
Took it to Advance auto and had them check the CEL, and it had two Camshaft Position/Angle(not sure which it is on these cars) Sensor codes don't remember exactly what the codes were, but both were saying it wasn't working right.
Checked out the sensor and somehow the plastic clip on the connector had broken off and the plug slid out.
Well cut it off, and grabbed the one off the Eclipse shell and soldered it on, and hoped it'd solve my problem.
It still misfires when you start moving, but then starts running fine around 2k RPMS and above, and while going up any incline, doesn't loose power unless its a steep incline, even then its very little, it just sounds horrible.
After I get home in the AM from work, it'll be parked till I figure this misfire out, don't want to take a chance of blowing the motor or something.
Now the Talon has sat for over a year between the previous owner and me with 3/4 of a tank, and I changed the fuel filter(which had some lovely smelling black crap coming out of it), could the gas be bad/contaminated?
Or maybe the Cam sensor just went bad somehow from the motor swap?
Any other ideas on what this could be, its only started AFTER the motor swap, so I'm thinking its something wrong on the Talon maybe.
