Kayo Stanciu
- 89
- 1
- Feb 9, 2016
Rosamond,
California
Having somewhat of a head scratcher.. my car is having a bogging issue when at WOT.. I checked for boost leaks already and I have none, spark plugs are new and gapped at .28, and the wires are also about a month maybe a little more old. CEL is on for fuel trim but not sure where to start on that.. any ideas on what it can be.. it drives fine if I slowly build up speed til about 4 1/2k-5k Rpms or if I step on it the car just feels like it hit a wall and bogs once again a boost leak test was performed and nothing was leaking..had a for installed and it’s set at 50psi I have 550 RC injectors and a 255 walbro pump. My AF ratio is all over the place jumping from 10-16.. on my apexi safc the karman reads roughly around 300-380hz cruising and when get on the throttle a bit more is around 650ish.. anybody else have this problem? So s BLT was done and there were no leaks but the bov one I had found but I fixed that and r checked it and had no more after that.
Also my mpg is real shit took quarter of a tank at 47 miles on it
Car is manual
Car is manual
