Twizted99GSX
- 140
- 5
- Oct 12, 2014
Champaign,
Illinois
Hello Dsm'ers..
I am here today because I THOUGHT I had a SHOP put in my Clutch about 2 yrs ago... I was told to do a breakin process. I did that and I waited like a good boy to get into it and start racing.. I bought a ACT Streetlite Xact flywheel & CenterForce Dual Friction Clutch... before I stored my car for the season i started noticing at HIGH RPM my clutch would start to slip and i didn't understand why... So when i took the engine out i looked at the Clutch and this is what i found.. im not sure if there is damage or what is exactly Wrong... i do know that i have seen different setups on eclipses so i am wondering is this a good setup or did i not get the proper applications... i seen Fidenza Flywheels and ACT 2600 or 2700 Clutch.. So i was wondering is this a good set up and is it still good to use or should i swap out for new clutch ,flywheel or both,... One thing though i was looking at the Clutch plate and it said GREDDY or EXEDY (3rd pic Down) on it and few other things didn't seem to match so i was wondering if that was part of CenterForce Clutch or did it get swapped for another part and thrown in not to be found till its taken apart.. Just hit me weird that Greddy would be Stamped on a CenterForce Clutch.. Ill try to post the pic i took of it... Let me know what you guys think..
Is my Flywheel still good i seen marks but idk if that means much.. And i know its been in there for few years but it wasn't driving that hard a few races and stuff on weekends but the ORANGE coating on the outside is all beat up and Gouged.. Is that from normal wear an tear or improper break in or anything?
I thought that maybe a part was switched or idk just had issues with the clutch even after proper break in time and miles..
This is the Clutch i bought the outside looks like it but way beat up and the Clutch plate not so much..
https://www.summitracing.com/parts/...99/make/mitsubishi/model/eclipse/submodel/gsx
Not a trans Tech.... HELP... hehe
Thank you and BE BLESSED
