Dsmbiz26
- 3
- May 27, 2017
Salem,
Massachusetts
So, quick backstory. I've had my dsm since I was 18(27 now) due to having other cars, having a baby and life I've neglected her for the past cpl years ;(
But things are starting to look up financially and it's time to get her going again. The last time she was running I hit some boost creep and my 16g ended up grendading and the car died, would not stay running afterward.. Also, I would think the car could run on a blown turbo, but have read rare cases of it causing engine failure and I'm hoping that's not the case... I pulled the turbo, ic piping, intercooler and drained the oil. The only place I found metal shavings was right where my intake connects to the turbo. But the comp wheel was completely smoked. Anyways I want to get her going and I want to do a compression test before tossing money at her, but Ive since gotten rid of the blown turbo and have no way to warm the car up prior. If I do the test cold I'm aware the numbers won't be as high but will it still be good enough to see if all cyl are within 10% of each other? Any suggestions besides checking comp. Before going at it would be appreciated! Sorry for the lengthy read.
