Jsmo123
5+ Year Contributor
- 49
- 4
- May 17, 2018
Danville,
Kentucky
Any suggestions? Just totally ripped one of my stock ones out.
4g63t. Automatic trans
I have around $130 to spend.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Would it work the same for a 98 eclipse rs, I ended up calling and they said they only had manual mounts so it’s still confusing for meThey sell a prothane kit that has the engine and side trans solid mounts, as for the roll stops they are simply inserts like this:You must be logged in to view this image or video.
The part number for the kit is:
Prothane 13-1901
Now if you want a more affordable full solid mounts for your auto this is what I did and it worked incredibly well! For the front and rear roll stops:
Just buy 2 of the 90-94 front prothane solid mounts part number is in the picture:You must be logged in to view this image or video.
As for the left trans mount and the right engine mount you'll need to buy 2 of the:You must be logged in to view this image or video.
So all you'll need to do for all 4 is press out the old mounts and rings lube up the new prothanes and press them in.
Here are mine as you could see I got rid of the other inserts:You must be logged in to view this image or video.You must be logged in to view this image or video.
Installed, if you zoom you can see 3 mounts imstalled:You must be logged in to view this image or video.
And since the bushing is big on the front and rear roll stops there is a write up on how to fix that:
http://www.dsmtuners.com/threads/1g...tor-for-using-stock-size-smaller-bolt.492693/
Just a forewarning, it's gonna be a little bit more difficult installing the more solid set as it's harder to pry and pull the engine and trans for lining up the bolt holes. Any question feel free to ask.
