Auto transmission shift shock between 1st and 2nd
Posted by ck1938, Oct 14, 2006
Please Support ExtremePSI
  1. ck1938
    ck1938 Probationary Member
    33
    Joined Jul 26, 2005
    Atlanta, Georgia
    Hey there, I checked the auto transmission forums and the only similar post I could find indicated I should get a new TCU, which I've already done. So forgive me if I missed the posting that answers my question.
    When the car shifts from 1st into 2nd there's this thunk. It feels like the car hits this threshold and needs just a little extra oomph to push through it. When the car gets that oomph it pushes through that threshold and jumps forward and you can feel and hear the shift inside the cabin. Vrmmm - THUNK- Vrmmm. When I'm going from 2nd to 3rd or into overdrive I don't have the problem. Something similar happens going from 2nd into 1st but not as bad. Not yet anyway. Any advice besides getting another TCU? They are kind of pricey.
    Log in/Register to remove ads
  2. xioca
    xioca Proven Member
    566
    Joined Oct 12, 2005
    Fort Wayne, Indiana
    Warm your car up and check the tranny flued level and make sure it goes all the way up to the hot line.
    Mine used to kind of grind into a gear, this fixed it and seeing as it's free it doesn't hurt to check it.
    My DSM:
    Loading...
  3. gsxgate24
    gsxgate24 Proven Member
    58
    Joined Nov 13, 2005
    Youngstown, Ohio
    Im having tranny issues too. I'm an auto gsx and when I come down to a stop it grabs hard into first gear and slams me to a stop. Also after I start the car for the first time, I let it warm up and I drive up to the first stop sign my car kicks out of gear. I have to put it in park and shut the car off wait a second and start the car back up and then put it in drive and after that it doesnt do it again. just in like the first 30 seconds of driving
  4. jabinya
    jabinya Proven Member
    104
    Joined Mar 7, 2005
    m, Ohio
    When you check your transmission fluid level, make sure the car is in neutral and the E-brake is engaged. Checking the fluid level in park will give a different, inaccurate reading.
    My DSM:
    1995 Eagle Talon TSi AWD
    14.351 @ 95.710 MPH
    Loading...
  5. ck1938
    33
    Joined Jul 26, 2005
    Atlanta, Georgia
    The fluid level is right at the hot line.
  6. ck1938
    33
    Joined Jul 26, 2005
    Atlanta, Georgia
    Are you getting any error codes? Mine was doing something simlar and it turns out the TCU was the culprit. I'm just wondering if I might have bought the wrong replacement computer for my transmission.
  7. ck1938
    33
    Joined Jul 26, 2005
    Atlanta, Georgia
    I think I might have fixed it. I've had a vibration in the lower gears too so I checked the motor mounts. The bolt holding the rear motor mount in place had fallen out. I jacked up the engine and replaced the bolt. Took it for a drive and the vibration was gone and the thunk seems to have disappeared. I'll update the post if anything chnages. Thanks for your help.
  8. gsxgate24
    58
    Joined Nov 13, 2005
    Youngstown, Ohio
    does anyone have any idea what is up with my tranny?
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
