forcefed86
- 1,007
- 12
- May 23, 2006
wichita,
Kansas
Setup on bottom of post.
So I want to know if I can run the door speakers on the head units rear channel, and dash speakers on the fwd channel. Then either run the sub rca outputs to my amp powering my 6x9's. Or just tap the door speaker speaker wires and run those to the amp.
Theory is (and I may be wrong!) I'm trying to not split the wattage for the door and dash speakers. If I just tap the rear speaker wires and run them to the amp will that still draw current/watts from the head unit? Ideally I'd like as much wattage to the door and dash speakers as I can, but would still like to retain the 6x9's sound quality on all frequencies.
If I run the 6x9's with the sub outlet is there a way to pick up high and mid signals as well as bass lows?
Hope that made sense. I'm no stereo guy.
Thanks!
1993 talon. TSI
Head unit is a 50w per channel peak. 18w rms.
I had some 5.25" rockford fosgates 2-35watt RMS (Under powered a bit I know, but free)
Boss 4" 20w rms 50 peak for the front.
Sound stream SST-6.9's 150rms 300 peak.
D400.2 DIABLO 2-CHANNEL 800 Watt MOSFET AMP 2 channel 150rms @ 4 ohm.
Thanks!
1993 talon. TSI
