diambo4life
- 1,499
- 323
- Apr 18, 2002
Edmond,
Oklahoma
I may have missed it but was the knock sensor replaced?
Note: This feature currently requires accessing the site using the built-in Safari browser.
Wow. I'm very surprised that it responded to all that fuel. That's good to hear though.
Yep. Whatever they flow at 43.5psi.
that does seem kinda low. I was in that area at ~122-125 mph traps.@bastarddsm
OK, this is retarded, ha ha. So I just found an old log from my 128mph pass at roughly the same boost (28psi; although on that setup, 28psi held through the whole range, whereas now it peaks at 28psi right off the bat falling to 24psi).
On that 128pass, the math works out to 45.76lbs/min.
So how does a full weight car car flowing 45.76lbs/min trap 128?
If all this math is right, I am flowing 4-5lbs/min MORE now than I was then...
Lets see your equation..I am doing the math wrong somewhere. My results using that formula are 64lb/min. Link is saying 51.5lb/min. No way im getting 64lb/min from a s256.
