Please Support ExtremePSI
Please Support STM Tuned
arp torque specs
myblack98gst
578
Jun 22, 2003
Elizabethtown, Kentucky
alright I am going to be assembling my motor later this week, but I need to know the torque specs for the ARP head studs and main studs (using ARP lube). I am reusing these parts from another motor I had so I no longer have the packaging.
motor Specs.
90 6 bolt block (decked,bored, align bored, etc...)
crank turn .010 over
Clevite bearings
Eagle H-BeaM rods with 3/8" ARP
Wiesco .020 over 9.0:1 compression pistons
Mitsubishi multilayer headgasket
if you know the torque specs let me know PLEASE!
Break yes, but remember they can stretch as well. Use ARP lube, and 3 stage it to 85ft/lb. Don't screw around with any other type of lube... use what's recommended from the fastener's manufacturer.
I saved the instructions from my ARP's and it clearly says at the bottom that IF using motor oil then you want to torque them to 120 ft lbs. However I also recommend using ARP's moly lube. You can get it at summit racing or even ebay sometimes.
^^ Exactly I dont know why everyone is saying don't mess with using motor oil use the moly lube when it has instructions how to do it on arpies website. Has anyone had a bad experience to back it up that it's not good to use oil?
the moly lube is like $3. Do what you think is best. You are the one who has to put it together and drive it.
