re-rx7
- 349
- 0
- Jul 19, 2011
ardmore,
Oklahoma
Well the reason I say it will never be larger than a T28 is that Im buying a MK4 supra in june.
Note: This feature currently requires accessing the site using the built-in Safari browser.
I think im gna tune for 18 psi to be on the safe side. Then after i get the studs I will up the boost to the 20-21 area. The way it sounds All i need to change them is a torque wrench and breaker bar.
I have the same SMIC. I would not consider it to be your limiting factor. It's very efficient.
numbers?I run also run the Hahn SMIC with the FP BT-28 & i'm very happy with this set up & i also run ARP headstud's to be on the safe side.
I like it..Its subtle and i trimmed my factory duct to make it fit. Plus, with a FMIC i would want to build a functional scoop just like the factory one up front to duct air into the rad and I/C.For the T28, your looking at about 400 rpm worth of lag increase going to an FMIC. For the labor and headaches that an FMIC poses, the HRC sidemount upgrade would be very attractive to somebody with a T28.
