Please Support Rix Racing
Please Support ExtremePSI
2G Are Prothane auto trans bushings same as manual?
Type1DSMr
1,114
149
Jul 27, 2014
Jasper, Indiana
Need some clarification on 2g Prothane bushings. I found some older information that says the bushing are the same, just not the the roll stop inserts. Is this correct? The Prothane part numbers are 13-501-bl and 13-503-bl. I'm looking at replacing the mounts with Prothane bushings with an OEM rear mount and a Boosted Fabrication front bar.
Did you end up trying this?
I bought a manual kit and everything fitted just fine, roll stop inserts aswel
Very nice. I just bought the mounts as I didn't need the roll stops. I'm using a front bar with a poly mount built in and Adams custom rear roll stop poly mount.
