Are all 2g transfer cases interchangeable?
Posted by ileagleracing, Nov 14, 2017
Please Support Magnus Motorsports
  1. ileagleracing
    ileagleracing Supporting Member
    185
    67
    Joined Sep 27, 2007
    Montreal, QC, Canada
    If I buy a used Manual 2g transfer case for my 98, does it matter what year the replacement is from?
    Log in/Register to remove ads
    My DSM:
    1998 Eagle Talon TSi AWD
    Autocross Build
    313 whp   305 lb/ft
    1995 Eagle Talon TSi AWD
    Autocross Build
    160 whp   190 lb/ft
    Loading...
  2. Black95TSIawd
    Black95TSIawd Proven Member
    1,607
    256
    Joined Jan 28, 2003
    Dirty, New Jersey
    Yes. Get one from a 97+.
    My DSM:
    184.4 whp   251.0 lb/ft
    1997 Mitsubishi Eclipse GSX (sold)
    Drag Race Build
    20g   manual
    Loading...
  3. ileagleracing
    185
    67
    Joined Sep 27, 2007
    What is the difference? Is it internal, or would it not even mate up to the trans or drive shaft?
    My DSM:
    Autocross Build
    313 whp   305 lb/ft
    Autocross Build
    160 whp   190 lb/ft
    Loading...
  4. 91talonts1
    91talonts1 Proven Member
    494
    164
    Joined Dec 29, 2008
    Spencer, North Carolina
    Internal. Ring gear in the trans must match the t case. 95-96 has 58 teeth, I believe the 97+ has 59.
    My DSM:
    1997 Eagle Talon TSi AWD
    Drag Race Build
      manual
    Loading...
    SAKJR likes this.
  5. GRNDSM
    GRNDSM Moderator
    1,935
    63
    Joined May 16, 2002
    Chelmsford, Massachusetts
    Externally, they look the same. But ratios are off, ever so much. Just mark it with the sharpie and count ;)
    My DSM:
    1996 Eagle Talon TSi AWD
    Autocross Build
    12.9 @ 103 MPH
    Street Build
    11.74 @ 118 MPH
    1994 Eagle Talon TSi AWD
    10.123 @ 138.060 MPH
    Loading...
  6. pauleyman
    pauleyman DSM Wiseman
    4,424
    701
    Joined Nov 19, 2011
    oklahoma city, Oklahoma
    If you happen to have the trans out it is possible to swap a ring and pinion on the front diff and use a 91-96 tcase.
    My DSM:
    Street Build
    T25   manual
    Loading...
  7. 1990TSIAWDTALON
    1990TSIAWDTALON Moderator
    2,682
    772
    Joined Nov 14, 2013
    Independence, Kansas
    What is the 1g auto count? I have a spare auto 1g (I hope) case that I want to make sure of.
    My DSM:
    1992 Eagle Talon TSi AWD
    Street Build
    14b   automatic
    1990 Eagle Talon TSi AWD
    13.620 @ 108.460 MPH
    13.612 @ 107.760 MPH
    Loading...
  8. twicks69
    twicks69 DSM Wiseman
    3,021
    429
    Joined Mar 12, 2004
    Milwaukee, Wisconsin
    Regarding transmission front diff ring gear tooth count vs. transfer case ring and pinion tooth counts:
    1990-1996 5-speed transmissions had 58-tooth front diff ring gear; 1997-1999 had 57-tooth front diff ring gear.
    OEM 2Gb 1997-1999 DSM transmissions that have not been fooled around with will have the transmission code of W5M33-2-MUZT. This one will have the 57-tooth front diff ring gear. There are others, but they are found in things like the Evo 3 (63 tooth) or RVR (57-tooth) that would use a 1997-1999 transfer case as well.
    The 1997-1999 transfer case is a 1.074 final drive ratio and consists of a 29-tooth driven gear (pinion shaft to driveshaft) and 27-tooth drive gear (side cover gear).
    Now, if you are dealing with a transmission that is from 1990-1996 OR using a front diff ring gear swapped from a 1991.5-1996 transmission with 58-teeth and the tooth profile matches the pinion shaft profile, you can simply swap the ring gear by itself, BUT there were two early variations before 1991.5 that had different tooth profiles or pitch angles and had matching output pinion shafts that need to be swapped together to be used.
    The 1990-1996 transfer case is a 1.090 final drive ratio and consists of a 24-tooth driven gear (pinion shaft to driveshaft) and 22-tooth drive gear (side cover gear).
    Now, the easiest way to check is to simply unbolt the 5x 14mm head bolts holding on the side cover. Then, hit the input sleeve with a dead blow hammer and the cover pops off. Count the teeth on the drive gear; it will be 22 teeth for an auto or 5-speed 1990-1996 transfer case; and it will be 27 teeth for an auto or 5-speed 1997-1999 transfer case.
    If you are too lazy to take off the cover and you have a spare transmission output shaft sitting around, then use a sharpie marker and mark a starting point on the input sleeve and the tail shaft, then count your revolutions until the markings match back up. 12 revolutions = 1990-1996, 14 revolutions = 1997-1999.
    If you need to do the same with the transmission, that can be done as well by counting revolutions of the front diff ring gear; 4 revolutions = 58 teeth, 5 revolutions = 57 teeth.
    Now, if you put on a transfer case with the wrong final drive, your car will act very squirrelly. Your front wheels will be spinning at a different speed than your rear wheels by about 4 mph at speeds. Handling will feel awkward, the car will feel like it is loading up alot and you can overheat or kill a head gasket or other components. You will also nuke your transmission viscous coupler for the center differential and can damage other components.
    My DSM:
    1999 Mitsubishi Eclipse GSX
    Drag Race Build
    9.499 @ 155.00 MPH
    Loading...
  9. 1990TSIAWDTALON
    2,682
    772
    Joined Nov 14, 2013
    Thanks, very informative Tim!!!!
    My DSM:
    Street Build
    14b   automatic
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrications OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports Tire Rack VR Speed Factory
