staztrx250
- 182
- 1
- Mar 29, 2010
Green Bay,
Wisconsin
Hey i just picked up a good AR.60 Garrett AiResearch T04 Turbo for free. Does anyone have a compressor map? Anyone ever run anything like this? what could it be compared too.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Still doesn't tell us shit about the wheel specs.
Probably a S-trim compressor mated to some giant turbine wheel (O-trim, P-trim) designed for use at low-boost on a large-displacement diesel engine. Has no place on a gasoline engine....it would make roughly the same airflow as a 14B or Small 16G, but spool like a GT40; hence the reason it was free.
The only way you'll profit anything from this turbo is if you break it down- scrap the turbine housing, sell the turbine wheel, compressor wheel, and center housing to someone for parts once they're identified.
Thoughts are fun and its no loss if it was free.Or make a jet out of it.
