Please Support STM Tuned
Please Support ExtremePSI
Any one tried fitting 3000gt front lower control arms to 1g dsm or gvr4?
is there a specfic reason for this i know one of the rears work but i dont think the fronts do
The 3000gt lower arms are very beefy pieces & if they do bolt on they will be an upgrade as there designed to hold a big v6tt unit, im thinking the 94-99 facelift arms would be the ones to try (same slip on rear bushings as 1g/gvr4), alot of the bolts & nuts around the arm are same part numbers between 1g/gvr4 & 3000gt vr4 according to oem parts catalog, the front bushing bolt is the same m12x135 long, the ball joint nut is same m12 MS440003 part number, the dsm/gvr4 rear bushing would have to be used as the 3000gt one is slightly different shape from i can see in pictures
(also the 1g/gvr4 & 3000gt use the same oem sway links front & rear)
Why is an upgrade needed? Breaking a lot of front control arms? I'd rather keep them as light as possible. Measure from the front bushing to the ball joint. Maybe they give you some free camber?
