ForsakenLash
- 156
- 0
- Mar 15, 2013
Jacksonville,
Florida
Ok, so I have an issue with my antenna that I need some help with. I have a base RS model with the whip style antenna, and for some reason the antenna gets poor reception in a lot of places. Here's the weird thing, it seems worse when I have my phone charging in the cigarette lighter port. I have checked every possible way for a wire grounding out that may be pulling signal and have found nothing. Is it just time for a new antenna?
Also when I have my phone charging and connected to the AUX port on the head unit, I can hear a whirring noise that matches the RPMs so to speak. As I accelerate it becomes higher pitched and when I shift it gets lower and goes higher as I accelerate. Someone did have an amp and sub wired and they ran the remote wire to the fuse for the lighter port and wrapped it around, so now there is a wire around the fuse and I cant replace it because a plain fuse wont fit anymore. Could that be the cause?
Last thing I promise, I had my center console pulled out looking for grounds and found this plug.... anyone know what it is?
