PlanZero
- 1,516
- 263
- Aug 13, 2013
Easton,
Pennsylvania
The car is a 96tsi. The cas is bad. I have a 1g black top cas which I'm going to install as per RRE/ Magnus directions. I have two questions:
I have a spare 97 ecu I was going to use so I don't have to switch pins in the 96 ecu, so now it will be a 1g CAS in a 2ga with a 2gb ECU. As far as I can tell the instructions for making a wiring harness are the same for 2ga and 2gb, is that correct?
Also, if I'm using the 2gb ecu I don't need to swap plug wires, correct?
