1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
1G Alternator
Posted by tk106, Mar 19, 2018
  1. tk106
    tk106 Proven Member
    641
    69
    Joined Sep 11, 2017
    Cincinnati, Ohio
    My DSM:
    1992 Eagle Talon TSi AWD
    Street Build
    16g   manual
    Loading...
    Featured Products from our Supporting Vendors
  2. jakk220
    jakk220 Proven Member
    1,061
    169
    Joined Nov 13, 2010
    Akron, Ohio
    No. I wouldn't think it is false advertisement. They do have 90amp alternators for our cars.
    Yes, even though it is from Canada it should still fit your car.
    My DSM:
    1997 Eagle Talon N/T (sold)
    Autocross Build
      manual
    1993 Mitsubishi Eclipse GSX
    Street Build
    16g   manual
    Loading...
  3. mitsubishikid
    mitsubishikid Proven Member
    787
    165
    Joined Jun 8, 2009
    Turlock, California
    "91-"92 galant vr4 alternators had the 90 amp alternators in the USA, and they fit in 1g dsms no problem, you just have to remember to add a bigger alternator fuse, I am using a 100amp fuse with my 90 amp alternator setup and have had no issues.
    My DSM:
    Loading...
    1990TSIAWDTALON likes this.
  4. tk106
    tk106 Proven Member
    641
    69
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Thanks for the info fellas! I wouldn’t have known to upgrade the fuse.
    My DSM:
    Street Build
    16g   manual
    Loading...
  5. 1990TSIAWDTALON
    1990TSIAWDTALON Moderator
    3,126
    992
    Joined Nov 14, 2013
    Independence, Kansas
    I am with @mitsubishikid. Mine is a 96 Galant 90 amp alternator, plug and play but the parts store offers a "high amp" option when they look up alternators now and it is a 90 amp model. Use a 100 amp fuse like mitsukid. No grinding the block for clearance and all that stuff. Also...use LED bulbs where ever you can to take the load off the charging circuit and let it work for the ignition etc.
    My DSM:
    Street Build
    14b   automatic
    1990 Eagle Talon TSi AWD
    13.620 @ 108.460 MPH
    13.612 @ 107.760 MPH
    Loading...
  6. tk106
    tk106 Proven Member
    641
    69
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Just picked up the 100 amp fuse and ordered alternator from the link in OP. I did change all my interior bulbs to led. LED headlight bulbs are on my wish list since they're not too expensive now. I plan on changing all the exterior bulbs in the future. Will LED blinkers work with stock relays?
    My DSM:
    Street Build
    16g   manual
    Loading...
  7. Bud92gsx
    Bud92gsx Supporting Member
    7,872
    51
    Joined Jan 16, 2008
    Wisconsin, Wisconsin
    1g auto is ten more amps than manual if that helps you out.
    My DSM:
    1992 Mitsubishi Eclipse GSX
    13.300 @ 102.400 MPH
    Loading...
    mitsubishikid likes this.
  8. tk106
    tk106 Proven Member
    641
    69
    Joined Sep 11, 2017
    Cincinnati, Ohio
    There’s no difference as far as fitment from auto to manual. Is that correct?
    I ordered from low mileage parts.com yesterday and it hasn’t shipped yet. Did a little research and they have some complaints on BBB. Now I’m worried it’s not 90 amps or it won’t fit.
    Good to hear I have options if this one doesn’t work out.
    Thanks Bud!!
    Seems like many members have had issues w alternators from retail stores not lasting. Figured this one is most likely made by mitsu but I could be wrong. That’s why I didn’t order from parts store. Should have it by early next week. Plan on bringing it to advanced to have them check first before installing. I’ll post results.
    My DSM:
    Street Build
    16g   manual
    Loading...
  9. pauleyman
    pauleyman DSM Wiseman
    4,749
    812
    Joined Nov 19, 2011
    oklahoma city, Oklahoma
    LEDs arent without problems. Cruise control circuits on some cars see it as a burnt out bulb and cruise control won't work. Ask me how I know.
    My DSM:
    1997 Eagle Talon TSi AWD
    Street Build
    T25   manual
    Loading...
  10. tk106
    tk106 Proven Member
    641
    69
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Are you referring to the light on the dash? My cruise isn’t working. I prob will never change dash or instrument bulbs to leds
    My DSM:
    Street Build
    16g   manual
    Loading...
  11. boostdawd
    boostdawd Supporting Member
    1,098
    295
    Joined Apr 6, 2010
    phoenix, Arizona
    Hmmm. I never swapped out the fuse for the alternator after I did my Saturn alternator swap. It's been running well tho. :aha:
    My DSM:
    Street Build
    16g   automatic
    1991 Eagle Talon TSi AWD
    Drag Race Build
    GT35   manual
    1992 Mitsubishi Eclipse GSX (sold)
    Street Build
    16g   manual
    Loading...
  12. Bud92gsx
    7,872
    51
    Joined Jan 16, 2008
    No there is no mounting difference. I killed my auto alt, and had to use the one from my parts car talon 5speed. Added a crap ton of leds and havnt seen any charging issues. :thumb:
    My DSM:
    Loading...
  13. tk106
    tk106 Proven Member
    641
    69
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Thanks Bud! Are your blinkers LED's? If so, did you have to change relay?
    My DSM:
    Street Build
    16g   manual
    Loading...
  14. Bud92gsx
    7,872
    51
    Joined Jan 16, 2008
    Front, yes. Parking lights and corners. Stock relay, but the bulbs were from a vendor, not a dollar a dozen typical eBay leds. Had to get yellow for the corners, I have crystal headlights, not that it matters.
    My DSM:
    Loading...
  15. serviceguy
    serviceguy Supporting Member
    459
    34
    Joined May 11, 2002
    Clifton, New Jersey
    Canada 1Gs had 90A alternators, probably due to running daylights?
    My DSM:
    Loading...
  16. mitsubishikid
    787
    165
    Joined Jun 8, 2009
    Turlock, California
    Honestly if I were you I'd put in a larger alternator fuse anyway, just because nothing has happened yet does not mean it's not on the way.
    If you are using a 110 amp Saturn alternator, a 120 amp fuse should be good for your needs, you have little-nothing to loose by buying a $1-$5 fuse [or many wrecking yards would likely just give you one free] that matches your amps, honestly I feel it's worth it to do the job right.
    A smaller fuse for the job could blow out prematurely, too big a fuse for the job could cause a damage to the device it's supposed to protect, or in the worst case it could potentially start a fire, last time I checked shooting yourself in the foot isn't really an Olympic sport just yet, but I'm sure a lot of us would be medalists by now LOL I'm just kidding, seriously be safe and get the right amp rated fuse for the job, if you can get the exact amp fuse for the job that would be ideal, but if you can't find one in that size and style get the closest fuse that is rated higher then the output rating of the alternator.
    It's also worth noting that, using a thicker 4 gauge charge wire can be beneficial, especially if the old charge wires are damaged or corroded, new wire can have a really great effect on idle volts, and provides a more stable charging system to work with.
    My DSM:
    Loading...
  17. boostdawd
    1,098
    295
    Joined Apr 6, 2010
    phoenix, Arizona
    Thanks for the information. Your right. Better safe then sorry. Last thing I want is a voltage surge frying my ecu and link. I'll be sure to borrow one from the junk yard LOL
    My DSM:
    Street Build
    16g   automatic
    Drag Race Build
    GT35   manual
    Street Build
    16g   manual
    Loading...
  18. Macgyver'sDSM
    Macgyver'sDSM Proven Member
    79
    25
    Joined Feb 20, 2017
    On the lake, Wisconsin
    You should never increase the size of the fuse. That is dangerous to do without determining the size of the wire and what amperage it is rated for. Without creating a 120 amp load you can not say you have tested a 120 amp fuse in the circuit.
    My DSM:
    1995 Eagle Talon TSi
    Street Build
    GT35   manual
    Loading...
  19. mitsubishikid
    787
    165
    Joined Jun 8, 2009
    Turlock, California
    Because the stock wires are 2 -8 gauge wires, 8 gauge is rated safely at 50 amps x 2 =100 amp max... there are Saturn alternators that only deliver 90-96 amps so these units might be good to go with the 100 amp alternator fuse, which is what I'm running with my 90 amp gvr4 unit.
    My DSM:
    Loading...
  20. 1990TSIAWDTALON
    3,126
    992
    Joined Nov 14, 2013
    I had to change my flasher in the console, under the radio, in my 1ga when I went with LED's. It is a digital flasher and flashes at a constant rate under any load, get them at the auto parts store.
    Also I haven't had any problems with my auto parts store 90 amp unit, but I think excess heat does kill them.
    @pauleyman , could that be why I can't get my cruise to work???
    I can't even get the light on the dash to come on anymore and it worked for the first 2 weeks I had the car but has quit and I would LOVE for it to work again.
    Marty
    My DSM:
    Street Build
    14b   automatic
    Loading...
  21. tk106
    tk106 Proven Member
    641
    69
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Which vendor? I’d like to change all the exterior lights to LEDs but I am scared of the final cost
    I see. It was shipped from CT so we’ll see. Can advanced auto parts test the amperage?
    My DSM:
    Street Build
    16g   manual
    Loading...
  22. Vegas smith
    Vegas smith Proven Member
    2,113
    920
    Joined Dec 2, 2002
    Houston, Texas
    I have a Saturn 200a alternator that I use a 100a fuse with. I believe it's fine to use a lower amp fuse but you take the risk of blowing the fuse out. I just haven't gotten around to installing my 225a fuse as the car has been getting other work done.
    My DSM:
    1993 Eagle Talon TSi AWD
    Street Build
    GT30   manual
    1992 Eagle Talon TSi AWD (sold)
    16g   manual
    Loading...
  23. tk106
    tk106 Proven Member
    641
    69
    Joined Sep 11, 2017
    Cincinnati, Ohio
    I agree. Was only $3 and I’m sure that’s the write way
    I was looking at upgrading big 3 to 4g wires.
    Thanks Marty!! So I need is a digital flasher?
    She’s been on jackstands for a week now. Feels like watching paint dry every time I’m in the garage. Can’t wait til Monday.
    My DSM:
    Street Build
    16g   manual
    Loading...
  24. 1990TSIAWDTALON
    3,126
    992
    Joined Nov 14, 2013
    Yes. I picked mine up at O'rielly's but I am sure most parts stores stock them, just tell a knowledgeable parts guy what you are doing and ask if they have a replacement flasher that is for LED's, which will be a digital flasher. Mine plugged right in under the radio in the stock flasher location. They are very quiet, so you probably won't hear the "tick, tock" anymore but the turn signals will blink at a constant rate without the hyperblink problems.
    My DSM:
    Street Build
    14b   automatic
    Loading...
    Bud92gsx likes this.
  25. tk106
    tk106 Proven Member
    641
    69
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Awesome!! I’m lucky I have two knowledgeable guys at advanced that know their stuff. It gets frustrating when you get the new guy/gal. I try to be patient until they flat out lie because they’re not sure.
    My DSM:
    Street Build
    16g   manual
    Loading...
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Miller Import Parts Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
