Alternator belt screaming
Posted by bsendkew, Nov 20, 2011
Bolt-on Tech - 4G63 intake, exhaust, intake manifold, ignition, fuel system, cooling, etc.
Please Support Feal Suspension
  1. bsendkew
    bsendkew Proven Member
    DSM Profiles:
    Apr 25, 2011
    54
    east meadow, New_York
    My alternator belt keeps screaming. i tighten the bracket but then after like 3miles of driving it loosens and gets very tight. then it gets very hot and starts screaming. it is a brand new alternator, could i be missing a bracket or something?
    #1
  2. iugrad92turbo
    iugrad92turbo Proven Member
    DSM Profiles:
    May 22, 2007
    10,191
    231
    Kalamazoo, Michigan
    MMM did you try to adjust it, sounds either too loose or tight?
    #2
  3. agentorange313
    agentorange313 Supporting VIP
    DSM Profiles:
    Dec 21, 2008
    1,810
    49
    Westfield, New_Jersey
    Squeaking belts occur when there is moisture or some kinda of dampness/residue on the belt itself, or on the pulley that it mates with.
    Oil and coolant is very common to cause this, it has the potential to leak from various places on the engine and can get on the belts.
    Is your bracket loosening? or is the belt that loosening? If its the belt, just get a new one, take two min to put on, especially since you changed the alternator you have the ability to change the belt. If its your bracket that keeps loosening I would look into the thread and bolt that are holding it in place.
    When the belt is situated in position, and prepared to be tightened, there should be 1/4inch of play in the belt, if you depress it in the middle.
    #3
  4. jpmxrider489
    jpmxrider489 Supporting Member
    DSM Profiles:
    Apr 4, 2010
    1,554
    13
    pittsburgh, Pennsylvania
    I have the same problem but mine goes away after warm up. Its a common thing to have a loud belt with our dsms. I know a few people that have this issue.
    #4
  5. ricktb
    ricktb Proven Member
    DSM Profiles:
    May 20, 2007
    432
    4
    Edmonton, AB_Canada
    First time i thought i over tightened my belts, turns out they were still loose and make a screech sound. Tightened them up and sound went away. There are problems also if you do end up over-tightening. Can cause premature wear on pulley bearings and belt. There is a specification in your haynes manual. Something like 8mm deflection if measured from a line across the top edge of both pulleys. Also the pulleys have to be in line perfectly. I had to make adjustments on my steering pump to align the pulleys
    #5
  6. gofer
    gofer Moderator
    DSM Profiles:
    Feb 18, 2006
    5,312
    626
    South Gilbert, Arizona
    It could be the alternator itself too. I tightened an alternator belt so tight because it was pissing me off from the noise it would make that it snapped while I was driving, turned out the remaned alternator was the culprit. After I replaced it the sound disappeared.
    :dsm:
    #6
  7. TrevorS
    TrevorS Proven Member
    Feb 10, 2009
    515
    Newark, Delaware
    If the belt squeals, it's not tight enough. Just keep tightening in small increments until it stops. My experience with my '90 is you have to be careful about how the bolt is oriented. One can easily end up tightening against nothing, and so pay close attention to exactly how it's positioned when tightening.
    #7
  8. Bud92gsx
    Bud92gsx Supporting Member
    DSM Profiles:
    Jan 16, 2008
    7,812
    26
    Your moms house, BC_Canada
    Mine squeels only on startup.Nothing when warm...I need to tighten the belt is all..
    #8
  9. gusu
    gusu Proven Member
    Sep 9, 2009
    1,359
    24
    Keizer, Oregon
    You could also have bad alternator bearings but I would assume its the belt not being properly tightened first.
    #9
  10. gieri002
    gieri002 Proven Member
    Feb 25, 2008
    729
    Lake Minnetonka, Minnesota
    Make sure to disconnect your battery before tightening the belt! Let us know how it goes.
    #10
  11. TrevorS
    Feb 10, 2009
    515
    Newark, Delaware
    I see absolutely no reason for this and definitely wouldn't do that myself. Please explain!
    #11
  12. RamenPride
    RamenPride Proven Member
    DSM Profiles:
    Aug 18, 2002
    2,279
    51
    Virginia Beach, Virginia
    Sometimes the belt can screech if the crank pulley is going bad.
    #12
  13. bsendkew
    DSM Profiles:
    Apr 25, 2011
    54
    ok so its not the the bracket is loosening the belt just gets tight...what do u think?
    #13
  14. hhuricane
    hhuricane Proven Member
    Sep 16, 2009
    260
    3
    Calgary, AB_Canada
    Some brands of belts just like to squeal. I can't put Gates on mine or it howls, Dayco works fine though. If it has been doing it for awhile the belt could be glazed and you'll never get it to stop. Try a new belt tensioned properly.
    #14
  15. m1nd64m3
    m1nd64m3 Proven Member
    DSM Profiles:
    Sep 17, 2003
    456
    4
    chitown area, Illinois
    I had the same problem and could not get it to go away, tried everything. Ended up being the alternator.
    #15
  16. bsendkew
    DSM Profiles:
    Apr 25, 2011
    54
    like i said its a brand new alt. also it is a fully rebuild so everything engine wise i brand new or 100% restored. the belt i am using is a gates blue.
    #16
  17. gofer
    gofer Moderator
    DSM Profiles:
    Feb 18, 2006
    5,312
    626
    It doesn't matter, if the belts tight and it still squeals its the alternator. I went through three reman'd alternators before I found one that didn't howl at me every morning and piss off the neighbors.
    Heres the FSM page, torque everything to spec (the tensioner bolt in particular) and if the symptoms don't change then its the alternator.
    :dsm:
    #17
  18. josh408
    josh408 Proven Member
    DSM Profiles:
    Jan 29, 2011
    287
    10
    Bay Area, California
    Did you get the alternator from kragens or auto zone?
    #18
  19. Vladimir
    Vladimir Proven Member
    DSM Profiles:
    Apr 28, 2010
    158
    Hollywood, Florida
    The nost common reason why belts squeel are: loose belt, contaminated belt (oil, coolant, water), pulley problems such as bad or binding bearing, tensioner problems, improper belt routing...etc.
    If the belt is new and its not contaminated , check all the bearings, could be the altenator it self binding.
    Dont tightet the belt too much cause you put to much load on the bearings. Let it be tight, but not as tight as your body can make it.
    #19
  20. TexasTurbo
    TexasTurbo Proven Member
    Jan 19, 2011
    174
    9
    Austin, Texas
    Hey man, if your belt is squeaking then there is an issue. It's not a "this is just how DSM's are" kind of thing. DSM's are like any other vehicle in that the components that make it up are largely similar and serviced in the same manner as other vehicles are. A squeaky belt is a squeaky belt and there are known fixes for this issue. I wouldn't just "deal with it" as something that "these cars do."
    #20
  21. jcarmichael
    jcarmichael Proven Member
    DSM Profiles:
    May 3, 2011
    345
    Greenwood, Indiana
    simple question simple well stated answer :applause:
    #21
  22. turboglenn
    turboglenn Proven Member
    Nov 5, 2007
    5,389
    82
    RIpley, West_Virginia
    I had this issue once and it turned out the crank pulley was seperated, no matterwhat it would squeel, then i inspectecdand saw the split inthe rubber on the damper pulley
    chekc that too
    #22
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
