o0GuitarKid0o
- 1,064
- 152
- Dec 12, 2013
Winnipeg ,MB,
MB_Canada
Note: This feature currently requires accessing the site using the built-in Safari browser.
I'd go with a 1/2 watt if anything
okay so i had the battery unhooked then i hooked up the 1/2 first and plugged battery back in and no good so then i tried the 1/4 and still nothing the light is still on? any thoughts
Show me a picture of your multi meter when your testing your air bags resistance
You should also see the resistance of your delete plug to see if the wires are adding enough ohms to make your resister be a 2.6 k ohm or somethin like that
What gauge wire did you use?
Another possibility is that you need to somehow restart the SRS system,
Could there be that something else is wrong with the system how did you wire it?
Was the light on before you did this?
no it was off, i changed the wheel and bam the light was on, i was expecting it to pop on im building a drag car but i still want pass airbag, and i didnt use any wire i just stuck the resistor directly to the wires!!
