Kringle
- 113
- 5
- Sep 29, 2015
Goldsboro,
North_Carolina
Probably a dumb issue or something easy to fix, but I'm at a lost right now.
Alright, before i pulled the motor to clean up the bay a bit i was working on tuning the car and a member mentioned that i had AFPR run over. So while the motor is out i wanted to address the issue. I have no clue what pump i have but i am pretty sure its not stock, came with the car. Trying to avoid extra work and cash that will come with snapping the bolts on the tank for the hanger if need be. Anyway, the previous owner has the fitting that converts the stock feed line to -6 an line and is utilizing the stock return. I guess my question is what would be a good course of action to fix FPR run over. My best guess is upgrade the return line to a larger size line maybe use the old supply line as a return? I have search for awhile (probably not looking for right answer) but can find anything, can someone please point me in the right direction?
Also as a side note, i have came to relize recently that i had my fuel pressure set to 43 instead of 37, would this cause the same symptoms as run over?
