1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
AF Evo 8/9 Factory Replacement Twinscroll Manifolds
Posted by Archer Fabrications, Sep 28, 2018
Please Support Southbay Fuel Injectors
Tags:
  1. Archer Fabrications
    Archer Fabrications Supporting Vendor
    6,055
    809
    Joined May 9, 2011
    Scottsdale, Arizona
    Archer Fab Evo 8/9 Factory Replacement Twinscroll Manifolds. 100% Stock Replacement, Large Runners to make the most out of your Stock, or Upgraded FP bolt-on Turbochargers! (external or internal gated).
    https://archerfabrications.com/af-evo-4-9-stock-replacement-twin-scroll-turbo-manifold.html
    •Like all our Turbo Manifolds, these are Hand Crafted in Scottsdale Arizona USA! Using only the Highest Quality Materials and Equipment Available, Precision TIG Welded with Miller Dynasty 210DX
    • Available with an investment cast 304 Stainless merge collector as standard.
    •NEW AF BILLET Stainless Steel 5 Axis CNC Machined Merge Collector, and New Stainless Steel 3D Port-Transitioned Head Flanges as an UPGRADE option!
    •Fully Back purged using commercial grade 99.9998% purity Liquid Argon.
    •Large diamiter Thick wall Sch40 Stainless Steel Runners. increased velocity & thermal conductivity to give an efficient heat energy transfer to the turbine wheel for increased spool up and optimal flow.
    •All flanges precision tig welded with thick heatsinks to reduce warpage during the welding process.
    •Gasket surfaces decked and polished for the perfect seal to your head and turbo.
    •Standard Port smoothing of runner entries and collector outlet for increased flow and reduced exhaust turbulence
    •Standard AF Polished Runner Finish, or High Temp Ceramic Coating in your choice of available colors.
    3F918EEF-24C0-4878-83F1-EC42C6865A5C.jpeg 5F21E9F9-AB0E-4B11-9E12-648821ECE1D0.jpeg F4338604-2EC3-4612-8F77-D6D88EB1F023.jpeg 14D3151F-C96D-486F-A723-71296CB236E2.jpeg 5AFAF1DB-0A0A-481B-A64C-CE25DC4B542A.jpeg
    Log in/Register to remove ads
    My DSM:
    1999 Mitsubishi Eclipse GSX
    Drag Race Build
    11.128 @ 132.5 MPH
    Loading...
    Mauispyder likes this.
    Featured Products from our Supporting Vendors
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Miller Import Parts Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
